ᐅ Can I convert PAX into a media cabinet?
Created on: 25 Apr 2021 18:37
MALE56
MALE56
25 Apr 2021 18:37
Hello everyone, I am considering converting a media cabinet and wondering if the IKEA PAX system is suitable for this purpose.
Specifically, I want to build a piece of furniture that can accommodate my TV, AV components, and possibly some decoration. The PAX system is primarily designed as a wardrobe, but its modular design and stability seem promising.
Has anyone here had experience converting PAX into a media cabinet? What challenges or advantages do you see, especially regarding ventilation for the equipment, cable management, stability, and any necessary modifications?
I look forward to your insights and tips!
GUMARTINA
25 Apr 2021 20:03
PAX can be modified, but make sure to pay special attention to the ventilation of the appliances.
You can often drill or router cable passages yourself quite easily. The stability is usually sufficient for the TV, but check how to remove the back panel if necessary.
KODAN32
26 Apr 2021 10:17
MALE56 schrieb:
The PAX system is primarily designed as a wardrobe, but its modular construction and stability look very promising.
This is exactly where the key lies: the PAX carcass is built to be sturdy, but it is mainly designed for vertical loads, such as clothes and shelves. For a media unit, this means you need to pay special attention to the area where the TV will stand, as point loads can be significantly higher there.
I recommend the following steps:
- Use PAX doors with glass or replace them to create an open look and allow heat dissipation.
- Remove or cut the back panel where power and AV cables need to pass through. PAX back panels are often thin; consider reinforcing stability with additional wooden battens.
- Plan ventilation slots or small openings, especially if installing AV equipment that generates heat.
- For stability, you can replace the lower feet with sturdier ones or anchor the cabinet to the wall.
Common mistakes include not adjusting the depth and height to fit the TV. Accurate measurements are essential here. Otherwise, PAX is an affordable and highly adaptable solution.
Rashadmeo
26 Apr 2021 16:42
KODAN32 schrieb:
Plan ventilation slots or small openings, especially if you are installing AV equipment that generates heat.
Exactly! I once converted a PAX into a media cabinet myself, and from my own experience, without proper ventilation, the device quickly overheats. Just drilling a few holes in the back panel and side parts really helped.
I also recommend using cable channels or cable ties to keep everything neat and tidy. If you like, you can remove some shelves and add LED light strips for a cool look!
PAX can be creatively modified – just give it a try and don’t overcomplicate things! Good luck with your project 😊
