ᐅ Bosch Smart Home – User Experiences
Created on: 19 Oct 2020 10:58
TobSte20
TobSte20
19 Oct 2020 10:58
Has anyone already had experience with Bosch Smart Home systems?
I am considering using it in my new build. The main functions currently in focus are: controlling the roller shutters, controlling the underfloor heating, and outdoor lighting control.
We are building a semi-detached house with a basement, two full floors, and a converted attic.
Do you have any experience with the range of the controller, and does anyone know if the range can be extended with a repeater (if so, which one)?
According to Bosch and Philips, the Bosch Smart Home system is compatible with Philips Hue. Does this apply only to lamps and lighting fixtures, or also to the Philips Hue motion sensors? I would like to install Philips Hue lamps on the exterior facade and control them via the Philips Hue outdoor motion sensor, integrating both into the Bosch Smart Home system. Will that work?
Thank you very much for your feedback.
Ybias78
26 Oct 2020 14:20
I'm just following it.
Mycraft26 Oct 2020 14:38
It is like any other island system. The possibilities are very limited, but it can be quite useful as a supplement. Why do you want to use the Philips BWM instead of simply the one from Bosch?
TobSte20
28 Oct 2020 21:52
Mycraft schrieb:
It’s like any other island system. Very limited in possibilities but useful as an addition. Why do you want to use the Philips motion sensor instead of simply the Bosch one?
As far as I know, Bosch does not yet offer an outdoor motion sensor...
I have also received feedback from Bosch Smart Home Service by now. Unfortunately, the Hue motion sensor cannot currently be integrated into Bosch Smart Home.
Mycraft29 Oct 2020 08:36
A true smart home requires a concept that integrates a large number of subsystems (ideally all) of a house/apartment/building and allows them to work together smoothly. BSH still has a very long way to go.
As mentioned before, it is enough to automate a few things here and there. However, BSH is still far (very far) from being a smart home.
