ᐅ BILLY Shelf with Wobbly Shelves – Additional Brackets Needed?
Created on: 9 Jan 2019 19:23
Lenochen
Lenochen
9 Jan 2019 19:23
Hello everyone, I recently noticed that some of the shelves on my BILLY bookcase from IKEA are quite wobbly, especially when I place a few books or heavier items on them. The shelves do fit into the supports, but they tend to tilt noticeably, which doesn’t seem safe in the long run.
I’m interested to know if anyone here has experience with adding extra supports or reinforcements to improve stability. Are there suitable metal brackets or other solutions that can make the shelf safer without major modifications?
I would greatly appreciate any tips or specific suggestions, especially if someone has already tried something like this. Thanks in advance!
semuneo
10 Jan 2019 06:47
Lenochen schrieb:
I’m curious if anyone here has experience with adding extra brackets or reinforcements to increase stability?
Hi Lenochen, I’m very familiar with that issue. I also have a BILLY shelf where the shelves started to become a bit loose over time. It’s really frustrating because it makes you feel uncertain when the shelf wobbles.
What helped me was installing hidden metal brackets from the inside, which I attached with small screws to the back panel and the underside of the shelf board. This tightens the panels and prevents the shelves from moving.
You need to be careful during installation so the screws aren’t too large and don’t split the wood, but otherwise it’s a relatively simple solution that makes a big difference.
If you want, I can explain exactly where I placed the brackets. 🙂
RAFAEL
10 Jan 2019 08:15
Lenochen schrieb:
Are there suitable metal brackets or other solutions to make the shelf more secure without major modifications?
From a technical perspective, I recommend:
1. Using small, flat metal brackets with a 90° angle on the underside of the shelves, screwed into the back panel.
2. Alternatively, wall anchors (also called wall plugs) can be used to install additional supports.
3. Important: Screws should be as short as possible to avoid penetrating through the panels.
If storing heavy items, it is also essential to check that the back panel of the shelf fits tightly and is not damaged, as it significantly contributes to overall stability.
All of these measures can be implemented easily without much effort.
Samuel
11 Jan 2019 11:03
semuneo schrieb:
What worked for me were hidden metal brackets from the inside, which I attached to the back panel and the underside of the shelf with small screws.
Top tip!
I did the same, and since then my shelf has been 100% stable. If you hide the brackets, they hardly show, and the effort is minimal.
A bit of DIY skill helps, but anyone should be able to do it. And if you want to make it look really good, you can even paint the brackets so they’re completely invisible. 😉
Mufato
12 Jan 2019 09:56
RAFAEL schrieb:
Use of small, flat metal brackets with a 90° angle on the underside of the shelves, screwed to the back panel.
Exactly like that. Simple, sturdy, proven. That’s all you need.
