ᐅ Additional Reinforcement for BILLY Shelving Unit: What Options Are Available?
Created on: 27 Jan 2018 08:23
Reogla
Hello everyone, I plan to reinforce my Billy bookshelf to make it more stable, especially because I want to load the upper shelves more heavily. Unfortunately, I couldn't find any official reinforcement kits from the manufacturer for the shelving units. My question is: What options are there to strengthen a Billy bookshelf permanently without major visual or structural changes? I am particularly interested in solutions that can be added easily without completely dismantling or altering the bookshelf. Does anyone have experience with additional reinforcements such as metal braces, brackets, special screws, or alternative materials? Thanks for your advice!
Jan31
27 Jan 2018 14:57
Metal brackets on the sides make a big difference. Secure the back panel. Adding more has little effect; otherwise, it’s better to choose a different shelving unit.
pikin
27 Jan 2018 15:23
Reogla schrieb:
What options are there to permanently reinforce a BILLY shelf without major visual or structural changes?
The main issue with the BILLY shelf is the shelving material, which bends under load. A very effective and visually unobtrusive solution is to install metal profiles (e.g., aluminum U-profiles) underneath the shelves. These profiles are fixed with small screws and are slim enough to be barely noticeable. Compared to wooden strips, they are stronger and take up less space.
Additionally, the shelf should be securely fastened to the wall—this improves stability and prevents tipping.
baelku
27 Jan 2018 16:01
Simply use metal brackets and screw them to the wall. This way, the shelf can also support heavy loads.
Reogla
27 Jan 2018 16:38
Thank you for the previous feedback, very helpful! I have a specific question: Would it be problematic to attach a plywood panel in the center on the back side in addition to the metal brackets and the back wall? I think this could increase stability, but I am unsure about potential stresses in the wood or the overall aesthetics. What do you think?
Gino38
27 Jan 2018 17:11
Reogla schrieb:
Would it be problematic if I attach a plywood panel in the middle of the back, in addition to the metal brackets and back panel?
That can definitely improve stability, provided the panel is securely fastened. Plywood is generally strong enough and can be easily fixed with screws. It is important that the panel is not too thick, so it does not complicate mounting to the wall. Wood tension occurs only if the surrounding conditions vary significantly (humidity, heat), which is usually not the case with BILLY indoors.
Genevieve
28 Jan 2018 09:42
Gino38 schrieb:
Plywood is generally stable enough and can be easily fastened with screws.
It is also important to know whether the plywood panel will be glued or just screwed. Using wood glue creates an almost monolithic structure, which significantly increases the shelf’s rigidity. However, the panel must then be cut precisely to avoid stress.
If in doubt, it is better to screw and leave an expansion gap.
