ᐅ BILLY Shelf Loose Screws: How Can I Prevent This?
Created on: 27 Feb 2021 08:37
Andrew
Andrew
27 Feb 2021 08:37
Hello everyone, I have had a BILLY shelf from IKEA for some time now, and I keep noticing that the screws loosen over time. This is obviously frustrating because it affects the stability, and I constantly have to tighten them. I would like to know how to generally prevent this. Are there any special techniques during assembly, or is it worth using certain tools or screw additives to keep the screws firmly in place permanently? I suspect there might be issues with the material or the type of screws used. I would really appreciate any tips or experiences – also from general DIY work.
JORDON
27 Feb 2021 09:14
Hey Andrew, I know all too well the annoying issue with loose screws! 🙂 What worked really well for me is applying some thread-locking adhesive or just a drop of super glue on the screw. This prevents it from loosening due to vibrations. Of course, use it sparingly so you can still take the shelf apart if needed. Another tip, especially for BILLY, is to retighten the screws after about a week, once the wood has settled slightly.
Andrew schrieb:
Are there any special tips for assembly
Yes, make sure to screw in cleanly with even pressure, preferably using an electric screwdriver set to low torque to avoid overtightening. A bit of feeling makes a big difference! Good luck, and thanks for bringing up the topic—I'm sure many who have experienced this will appreciate it!
RonJarrett
27 Feb 2021 11:28
To prevent loose screws in furniture like the BILLY shelf, proper assembly is essential. It is important that screws are not tightened too much, as this can damage the wood and make holding more difficult over time. At the same time, they need to be tightened enough to secure the parts.
A reliable solution is the use of thread lockers, for example, a medium-strength thread locker (such as Loctite 243 or a similar product). This is applied thinly to the screw and helps prevent loosening due to vibrations.
Important: For regular use of the shelf (e.g., frequent loading and unloading), screws should be checked and retightened after a few weeks. Retightening after the initial assembly compensates for the settling of the wood.
I also recommend using a torque wrench or a cordless screwdriver with adjustable torque settings.
KODAN32
27 Feb 2021 14:53
Hello Andrew, I have also studied this topic in detail and have some practical tips that might help you:
1. Preparation: Make sure all parts and screws are clean. Dirt or grease on screws can change friction and increase the chance of slipping.
2. Type of screws: The BILLY shelf usually uses coarse-thread wood screws suitable for chipboard. Check that they are not damaged and replace any worn screws.
3. Working with wood: I recommend pre-drilling the holes with a drill bit slightly smaller than the screw before screwing in. This reduces the risk of splitting and provides better grip.
4. Threadlocker: Use medium-strength threadlocker (blue) only on screws that you don’t need to adjust frequently.
5. Retightening: As mentioned, make sure to retighten the screws after about 7 days once the wood has settled.
6. Additional method: Small felt or rubber pads between the back panel and the shelf sides also help to reduce vibrations.
If you like, I can write a brief step-by-step guide for optimal screw installation.
floga
28 Feb 2021 07:19
Hello Andrew, I can definitely understand how frustrating it is when the screws on the BILLY shelf keep loosening. Especially when you rely on stability, that can be really annoying.
JORDON schrieb:
Another trick, especially with BILLY, is to tighten the screws again after about a week
This helped me the most—to check the shelf again after a few days and retighten the screws. I hadn’t done that at first, and then the screws started coming loose.
Sometimes it also helps during assembly to avoid tightening the screws with full force at once, but instead work more carefully to avoid damaging the material. I noticed that with furniture made from particleboard, a gentle approach is especially important.
It would be great if more people here with similar experiences could share their tips. When it comes to screws in wood-based materials, there are certainly many tricks we can learn from each other. Good luck with your project!
