ᐅ BILLY Shelf Finish Fading – How to Refresh It?
Created on: 2 Nov 2021 08:37
dase70
I have an IKEA Billy bookcase that I have been using for several years. Unfortunately, the finish has faded over time and now looks somewhat dull, especially on the surfaces that are often exposed to light or frequently touched. It is the classic white painted model. My question is: What is the best way to refresh the finish on my Billy bookcase without having to sand down or completely repaint the entire cabinet? Are there any special paint pens, polishes, or other products that can restore the faded white to a brighter appearance? I’m looking for a solution that is as simple and low-effort as possible.
If anyone has experience with this issue or tips on the specific application, I would really appreciate a detailed response.
toril
4 Nov 2021 09:54
dase70 schrieb:
I am also interested in what exactly is meant by this "fine sanding" – how strong or gentle should I be, and with what grit?
To clarify:
For painted furniture made of MDF or particleboard, it is recommended to use sandpaper with a grit of 400 to 600 (fine) to properly prepare the surface for repainting. This will dull the glossy finish, which improves the adhesion of the new paint.
Procedure:
- Always sand with light, even pressure; avoid heavy scrubbing.
- Sand along the grain or in circular motions, depending on the surface, just enough to slightly roughen it.
- Thoroughly remove sanding dust afterward (vacuum and damp cloth).
I also recommend testing a small, inconspicuous area first to see how the surface reacts.
This will help prevent spots or uneven areas after painting. A lightly sanded base is always the foundation for a good result.
