ᐅ Installing BILLY Shelves in Alcoves – What to Keep in Mind?
Created on: 30 Dec 2023 08:47
Gipi50
Gipi50
30 Dec 2023 08:47
Hello everyone, I am planning to install a Billy bookcase in a niche and would like to benefit from your experiences and tips. Specifically, I am interested in what to consider when the height, width, and depth of the bookcase need to fit exactly into the niche, especially regarding secure mounting, possible modifications (such as shortening the back panel or wooden parts), and the use of a level to ensure the bookcase is not crooked afterwards. Are there any special considerations for mounting in a niche compared to regular wall mounting? I look forward to your practical advice, especially if you have encountered any issues or found creative solutions.
Dustin
30 Dec 2023 09:23
The most important aspect when installing into an alcove is to take precise measurements and, above all, ensure the wall is straight. You can best correct any unevenness with spacers or shims. Always use wall plugs suitable for the wall type when fastening.
Nathanaelk
30 Dec 2023 10:15
Installing shelves in a niche is more complex than mounting them on a free-standing wall. First, carefully measure the depth of the niche, as BILLY shelves are standardly 28 cm deep (11 inches), and any deviations may require adjustments. In tight niches, it may be necessary to shorten or even remove the back panel to properly fit the shelf. Be cautious during this process to avoid compromising stability.
Choosing the right fixing points is also important: especially in niches, the side walls—not just the back wall—may need to be used for mounting. It is recommended to secure the shelf with screws and wall plugs in at least two different levels to ensure stability. However, I advise checking the wall material beforehand for load-bearing capacity (e.g., concrete, drywall, etc.). For timber stud walls, pay attention to the placement of holes and the substructure. Also, use a spirit level for each component to keep the shelf perfectly horizontal.
A small tip: slightly trimmed baseboards can be used as a support if the niche is not perfectly rectangular and you need to balance out minor height differences. Finally, check whether you need to stabilize the shelf with brackets or additional supports if you have removed the back panel; otherwise, it might become unstable or wobbly.
SONLIS
30 Dec 2023 11:42
This is a good topic. Another important point is ventilation: moisture can accumulate quickly in recesses, for example in poorly ventilated rooms. Therefore, make sure to leave at least small gaps to the back wall or ventilation slots. Otherwise, your shelf may absorb moisture over time, which can lead to wood swelling or mold growth.
You should also consider the load: if the shelf is heavily loaded, the mounting must be sufficiently sturdy. Always use appropriate wall plugs and screws that are suitable for the specific wall thickness and material.
JORDON
30 Dec 2023 12:58
Hey, great topic, because I’m currently renovating too! 🙂 From experience, niches can be tricky since they leave very little room for tolerances. So before you start screwing anything in, always place the shelf in the niche without fixing it first and see where it doesn’t fit. If the niche has corners that aren’t perfectly straight, flexible shims are really invaluable – they allow for fine adjustments before everything is fixed in place.
And if you need to trim the back panel: do it in small steps, better to remove too little than too much, otherwise it looks odd and the stability suffers. A good spirit level really helps – sometimes the shelf looks flat when viewed from above but actually isn’t. ;-)
Elias
31 Dec 2023 07:51
I recently did something similar and want to encourage you if you’re facing a similar issue: My niche was somewhat irregular, so I had to adjust the shelf in several places. At first, I was unsure whether the structure would remain stable if I partially removed the back panel.
Nathanaelk schrieb:
 instead of shortening or even completely removing the back panel to optimally adjust the shelf.
This point made me a bit uncertain, but by adding extra brackets and screws on the side walls, I improved the stability. Don’t get discouraged; it can be a bit fiddly at times, but in the end, it works well! 🙂
