ᐅ Installing BILLY Shelves in Alcoves – What to Keep in Mind?
Created on: 30 Dec 2023 08:47
Gipi50
Hello everyone, I am planning to install a Billy bookcase in a niche and would like to benefit from your experiences and tips. Specifically, I am interested in what to consider when the height, width, and depth of the bookcase need to fit exactly into the niche, especially regarding secure mounting, possible modifications (such as shortening the back panel or wooden parts), and the use of a level to ensure the bookcase is not crooked afterwards. Are there any special considerations for mounting in a niche compared to regular wall mounting? I look forward to your practical advice, especially if you have encountered any issues or found creative solutions.
Gipi50
31 Dec 2023 09:18
Thank you in advance for your feedback! Regarding the back wall – do you have any experience or advice on whether it’s better to remove the entire back wall or just shorten it? Are there differences in how this affects stability and installation within the niche? And about fastening to different wall types: what is the best approach if, for example, the niche is made of drywall? Are standard anchors sufficient, or are special solutions needed? Thanks again!
gregto
31 Dec 2023 11:05
Regarding the back panel: It is often sufficient to simply shorten the back panel to fit the niche’s width and depth. The back panel is important for the stability of the BILLY shelf and provides necessary resistance against lateral twisting. If you completely remove it, you should definitely use additional brackets or braces on the back to ensure stability.
For drywall, you should use special cavity anchors or metal expansion anchors — standard plastic anchors usually do not hold well in drywall. Make sure to select anchors appropriate for the load and wall thickness. If you are unsure, consulting a professional can help determine the wall’s construction.
Additionally, it can be helpful to install a thin board as a support inside the wall if the anchors do not hold well — this provides more even load distribution.
INGRID34
2 Jan 2024 17:03
Just a quick note: Do not remove the back panel without additional reinforcement. For drywall, always use hollow wall anchors, not regular anchors. Also, before installation, check the wall for electrical wiring using an acoustic or electronic detector.
