ᐅ BILLY Shelving for Basement: What Precautions Are Recommended?
Created on: 8 Jan 2021 09:17
tarsi42
tarsi42
8 Jan 2021 09:17
Hello everyone, I am planning to set up an IKEA Billy bookshelf in the basement to store some boxes, tools, and supplies. Since the basement is somewhat damp and cold in places, I am wondering what precautions are advisable when installing and maintaining the Billy bookshelf to ensure the furniture lasts as long as possible and does not get damaged. What protective measures or adaptations do you recommend to prevent mold, moisture damage, or warping? Are there any special treatments or additional products that have proven effective? I look forward to your tips and experiences!
PAR63
8 Jan 2021 10:03
Hello tarsi42, your concern is very well expressed and important, especially for basements, which often pose challenges with moisture. I’ll provide a brief guide on possible precautions when using a BILLY shelf in the basement.
1. Location check: First, verify if the basement has extremely high humidity or mold issues. If so, you should avoid placing the shelf directly against damp walls.
2. Distance from the wall: The shelf should have at least 2-3 cm (1 inch) of space from the wall to allow air circulation. This helps prevent moisture buildup.
3. Moisture protection: The floor covering is important – it’s best to place a plastic or rubber mat underneath if the floor might be damp.
4. Impregnation or sealing: You can treat the BILLY shelf with wood protective varnish or clear primer to protect the wood from moisture.
5. Regular ventilation: Ensure good ventilation so that humid air does not accumulate.
6. Weight and load: Make sure not to overload the shelves as the material may warp otherwise.
In summary: maintaining distance, protecting against ground moisture, and regular ventilation are essential. If you like, I can provide details on varnishes or mats.
WARREN
8 Jan 2021 10:27
It is best not to place the BILLY shelf directly on the floor; use a rubber mat. Avoid contact with the wall. Ventilate regularly. Treat the wood with moisture protection.
toril
8 Jan 2021 12:15
As an addition: The BILLY shelves are mainly made of particleboard with a decorative foil, which is sensitive to prolonged moisture exposure. Therefore, maintaining a gap from the wall and using an underlay mat is essential to minimize moisture damage.
I also recommend using a dehumidifier in basement rooms with higher humidity. Studies show that material degradation in wood-based products is significantly reduced if the relative humidity is kept below 65%.
If you want to paint the shelf, I suggest using a water-repellent clear coat for wood that remains breathable. Fully sealed surfaces can otherwise trap moisture and promote damage.
Does this help?
rigau
8 Jan 2021 13:09
Important: Keep the shelf slightly apart from the wall, place rubber mats underneath, and ensure good air circulation in the basement. If there is moisture, it is better to use other types of furniture.
tarsi42
9 Jan 2021 08:22
PAR63 schrieb:
1. Location check: First, check if the basement has extremely high humidity or mold issues.
That’s a good point – so far, I haven’t noticed any visible mold problems, but the air often feels damp. Is there an easy way to measure the humidity in the basement?
toril schrieb:
I also recommend using a dehumidifier in basement rooms with increased humidity.
Could you recommend a specific dehumidifier that works well for a basement room of about 15 m² (160 sq ft)?
Regarding the sealing: How often should such a protective coating be renewed if I paint the shelf? Does it significantly increase durability?
