ᐅ What kind of maintenance does a Billy bookcase require in environments with high humidity?
Created on: 12 Nov 2019 08:24
talo36
I recently bought a Billy shelf from IKEA that I plan to place in a room with relatively high humidity. Since I expect humidity levels to frequently fluctuate between 60 and 80 percent, I’m interested in what kind of care or treatment the Billy shelf needs to stay stable for as long as possible.
Specifically, I would like to know if I should apply any special protection to the wood or surface, and if there are particular cleaning methods recommended for high humidity environments. Any advice on preventing swelling or warping of the material would also be very helpful.
Looking forward to your experiences and professional input!
maureo
12 Nov 2019 12:45
Here are the most important points for maintenance in high humidity conditions:
- Distance from walls and floor
- Regularly wipe dry
- Seal edges with waterproof varnish if necessary
- Ensure good room ventilation
Nothing more.
dijan
12 Nov 2019 14:02
Hey talo36,
I think it’s great that you’re taking such a systematic approach :-) Billy shelves are almost like an IKEA cult item, but they can really become a problem with moisture.
Here’s my two cents: Don’t place the Billy shelf in a corner without air circulation, that’s really bad for the wood. And don’t worry, consistency is key; apply a good protective treatment once and then just keep it as dry as possible!
Sometimes a small fan can help if the humidity is hard to control. ?
cassandra
12 Nov 2019 15:17
Regarding the care and protection of the Billy shelf in high humidity conditions, I can add the following:
The typical surface made of melamine-coated particleboard is quite resistant to scratches but not suitable for permanently damp environments.
Applying a water-repellent varnish to the edges extends its lifespan and reduces swelling.
Cleaning should always be done with a well-wrung, slightly damp cloth; avoid aggressive or abrasive cleaners.
Ultimately, only good indoor air quality with regular ventilation and avoiding standing moisture reduces the risk of damage.
ixlu1
12 Nov 2019 16:36
relupa schrieb:
Try to raise the shelf off the floor by attaching small felt pads to the feet.
That tip was really helpful for me too, perfect advice! I even put rubber feet under the shelf here, which protect against cold and moisture from the floor.
@talo36: If you haven’t done this yet, you should definitely do it. Since then, my shelf has been much happier 🙂.
Palenar
13 Nov 2019 08:09
Good morning talo36,
to add a bit more detail on the topic: If you decide to use a protective coating, make sure to let each layer dry thoroughly and lightly sand it before applying the next one. This helps the next layer adhere better and ensures optimal protection.
If your room still stays relatively humid, it might be worth considering a small electric dehumidifier. These devices maintain air humidity consistently between 40 and 60% and help protect furniture and building materials.
I would be interested to know if you can describe the situation in more detail, including how often the humidity rises and whether the Billy shelf is exposed to direct sources of moisture such as a kettle, windows, or a laundry area.
talo36
13 Nov 2019 10:43
Thank you all for the detailed answers and tips!
Situation: The shelf is located in an unheated basement room, which often experiences heavy condensation on the walls. The relative humidity usually fluctuates between 65 and 85%, especially during the colder months.
Currently, the shelf is placed directly against the wall, but I plan to use felt pads or spacers. Sealing the edges with paint seems sensible; I will probably get a suitable paint for that.
Ventilation is unfortunately difficult because the room is poorly ventilated and has no heating. I have also considered a dehumidifier—but not specifically because of the shelf. Thanks for the tip, Palenar!
Would a simple impregnation even make sense for melamine-coated panels? Or is painting the edges the only truly effective method?
