ᐅ Billy Regal tips for transportation.
Created on: 10 May 2022 08:42
PAULA4
I need some practical advice on how to safely transport a Billy bookshelf. I plan to take the shelf with me when moving into my new apartment, but I’m concerned about how to properly protect the individual boards and the frame to avoid scratches or cracks. Are there specific packing materials that work particularly well for this? And what is the best way to stack or secure the boards so they don’t shift during the move? Maybe there are general tips to keep in mind when transporting a Billy bookshelf to prevent damage.
Thanks in advance for your experience and recommendations!
Ramon4
11 May 2022 08:16
I would like to add that it can be helpful to tape the individual shelves of the Billy bookcase together with masking tape to prevent slipping—but make sure it does not leave any residue.
Also, the side panels should be stored in a protected position, as they can warp under prolonged loads.
If possible, work with several people when loading and unloading to avoid dropping the boards.
Above all: take your time and pack everything carefully. This will help avoid the hassle of potential transport damage.
V
Vinlen
11 May 2022 12:04
Ramon4 schrieb:
The side panels should be stored in a protected position, as they can warp under prolonged loads.
I agree with this. Regarding humidity inside the transport vehicle: wood boards and particle boards, like those used by Billy, react to moisture; therefore, it is important to have dry and well-ventilated transport conditions.
Additionally, it helps to check for damage or swollen areas before transport.
Sealing or cushioning the edges with rubber or foam profiles provides further good protection against impacts.
anken
12 May 2022 07:38
Additional tip: To prevent the boards from bumping into each other during transport, you can place cardboard strips or foam strips between them.
Also: Avoid placing heavy objects on top of the boards, as this can cause unnecessary pressure marks.
tyson51
12 May 2022 10:52
anken schrieb:
To prevent the boards from knocking against each other during transport, you can place cardboard strips or foam strips between them.
Exactly, and to add: place them on a flat, stable surface and avoid stacking them too high.
One more tip: if you rent a transport vehicle, check that the loading area is clean and dry before loading, as this makes a difference for the surface of the boards.
