ᐅ What is the best way to install BILLY shelves in basement rooms?
Created on: 24 Jan 2020 08:12
lisan
lisan
24 Jan 2020 08:12
Hello everyone, I am currently planning to install several Billy shelves in my basement and am looking for the best mounting options. The basement walls are partly slightly damp, and the floor is made of concrete. I don’t just want to place the shelves there; I want to secure them properly so they stand firmly and don’t tip over. I am also interested in which fastening materials work best for different wall surfaces like plaster, concrete, or sometimes slightly crumbly substrates. How do you handle this in basement rooms? Are there any special tips for preparation or moisture protection measures? I look forward to your experiences and advice!
DAMALO
24 Jan 2020 08:46
This is a very important question, especially in basements, where conditions differ significantly from living rooms or other living spaces. I personally struggled with shelves that were simply placed and eventually tipped forward because the floor was not completely level. Regarding wall mounting, I can only say that it makes sense to drill into stable points in the wall whenever possible. However, in damp basements, I am also concerned about damaging the walls or promoting mold growth. Perhaps other users have more experience with how to properly balance these issues?
bujufa
24 Jan 2020 09:23
As a general recommendation for damp basement walls, first perform a visual inspection for cracks or flaking. Before drilling, the surface should be dry and stable. For concrete walls, heavy-duty anchors such as metal expansion anchors or chemical anchors are suitable, as they provide high load capacity and reliable holding strength.
If the plaster is crumbling, it may be worth using stronger anchoring methods with epoxy resin-based adhesives or anchors. Alternatively, additional support elements under the shelf or floor fixings can help increase stability. It is also advisable to install a vapor barrier or appropriate moisture protection layers behind the shelves before mounting to protect the materials.
Guyju
24 Jan 2020 10:05
I would like to provide a simple step-by-step guide on how I install BILLY shelves in a basement, based on my experience:
1. Preparation: First, take precise measurements of the intended installation space and check the walls for stability. If the masonry is damp, be sure to perform a moisture test.
2. Substrate: For concrete or solid plaster, drill the holes directly using a hammer drill. It is important to use a drill bit suitable for the building material (masonry or concrete bit).
3. Anchors: For basement rooms, I recommend metal expansion anchors or chemical anchors, as plastic anchors can lose their holding power over time due to cold and moisture.
4. Installation: It is best to first level the shelf using a spirit level and then secure it to the wall to prevent tipping. Additional floor supports add extra stability.
5. Protection: If the shelf is in direct contact with the floor, placing a small pad made of plastic or rubber under the feet is beneficial.
Moisture protection can also be achieved by placing a thin PE film behind the shelves, which does not completely block air circulation.
lisan
24 Jan 2020 10:34
Thank you for your input. I have an additional question: How important is it to screw the BILLY shelves to the wall if the floor is only slightly uneven? So far, I have just placed the shelves against the wall in other rooms, but in the basement, I’m worried that the floor conditions won’t provide enough stability. Would angle brackets screwed into both the wall and the shelf be sufficient? And how would you approach a wall with plaster that is somewhat crumbling? Should the plaster be removed beforehand, and how should I choose the appropriate wall anchors?
Edric
24 Jan 2020 11:02
I would definitely recommend securing the shelf to the wall, especially in basements where moisture and temperature changes can cause the floor and walls to shift. Wall brackets or angle brackets are a simple but effective way to prevent tipping hazards.
Regarding crumbling plaster: If the plaster is loose, make sure to remove all the unstable parts. This is the only way to ensure the anchor holds securely. In my basement, I removed some of the plaster and then used anchors designed for basements, such as metal sleeve anchors.
