I have had a Billy bookcase from IKEA at home for some time, and I have noticed that the doors keep squeaking loudly at the hinges despite regular oiling. I have treated the hinges several times with machine oil, but the squeaking does not go away permanently and usually returns after a few days.
My question is: What could be the causes for the Billy bookcase doors continuing to squeak despite oiling? Are there any specific points or techniques to consider when dealing with Billy bookcases?
I suspect it might be due to the hinge design, dirt contamination, or possibly too little or the wrong type of oil.
I look forward to your insights and experiences—perhaps someone here is familiar with this issue and has a solution.
Hello LILIFU,
your problem with the squeaking Billy shelf doors is unfortunately not uncommon. Here is a brief, structured overview of possible causes and suggested solutions:
1. Type of oil: Machine oil is generally suitable but often too thin. The oil evaporates or gets pushed out, so the lubrication does not last. A thicker grease or a special silicone spray can work better in this case.
2. Cleaning before lubricating: Before applying lubricant, the hinges should be thoroughly cleaned of old oil residues, dust, and dirt. Otherwise, the grime mixes with the oil and can cause even more squeaking noises.
3. Type of hinges: IKEA uses simple, sturdy hinges. Sometimes they may sag slightly, altering the metal contact. A minor adjustment of the door can already help.
4. Mechanical wear: Especially with older shelves, the joints may be slightly deformed, causing grinding or squeaking sounds.
In summary, I recommend:
- Remove the hinges and clean them thoroughly (e.g., with brake cleaner)
- Then apply silicone spray or Teflon spray (not plain oil!)
- Align the door and tighten the hinges
If you like, I can send you more detailed instructions. Hope this helps for now!
FABIAN_DEO27 Jul 2016 08:56Lyndon55 schrieb:
Before lubricating, the hinges should be thoroughly cleaned of old oil residues, dust, and dirt. Otherwise, the dirt mixes with the oil and can actually cause more squeaking noises.I can only agree with that. In my experience, cleaning before lubricating is the crucial step that is often overlooked. Here is how I proceed:
1. Remove the door or the hinge plates if possible, to get optimal access to all parts.
2. Clean the hinges with isopropanol or brake cleaner. This removes grease, old oil residues, and dust particles.
3. Let them dry completely afterward.
4. Then ideally apply a high-quality, long-lasting lubricant such as lithium grease or a PTFE-based spray.
Regarding your problem with the squeaking returning despite lubrication: if oil is applied only to dirty hinges, the oil spreads out and quickly loses its effectiveness. Also, the hinges on Billy-style shelves are often made of nickel-plated steel, which is durable but not immune to wear.
Have you ever unscrewed the hinges from the door? How do the pins or joint areas look? Could they be worn out?
If so, the hinges may be mechanically worn, and simple lubrication won’t help anymore—in that case, replacement parts would be necessary.
I’m also curious how often the doors are used and whether they might be exposed to moisture or temperature fluctuations, as these factors can affect hinge performance.
FABIAN_DEO schrieb:
If so, it might be that they are worn out mechanically, and then just oiling won’t help—you would need replacement parts.Exactly, and in that case, I can only recommend staying calm and giving the hinges a little time. A few “squeaky greetings” are almost normal with Billy. 🙂
One more tip: Sometimes the cause is very simple—like if the door’s position has shifted slightly. A slight adjustment with an Allen key (typical for IKEA) can work wonders without needing any special oil. And if you want something to smooth the contact surface, graphite powder is best instead of oil—it lubricates dry and doesn’t attract dust.
Finally—and if nothing else works—the hinges can be bought individually at IKEA. The price is reasonable and replacing them is quick.
All in all: Don’t despair, every Billy door squeaks sometimes, patience is half the battle ;-)
Good luck!
