Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201811 May 2020 15:55
So it is a 0.3 meter (1 foot) cable and was included with the USG-XG. I haven't been able to find it for purchase anywhere. Only lengths starting from 0.5 meter (1.6 feet).
untergasse4311 May 2020 17:43
Since I am currently working with SMI again on another project and in our planning... how do you handle shading for the building? Standard KNX blind actuators, KNX drives, or also SMI?
rick201811 May 2020 18:21
KNX blind actuators. However, the motors have position monitoring and in some areas also sensors in the tracks. Part of the shading is cable-guided.
We have screens as shading.
For louver blinds, I might have considered SMI actuators.
Muc1985
12 May 2020 22:48
@rick2018 It’s amazing what has happened here over the past few months. All your posts make me want to see more!
Harakiri
13 May 2020 10:29
I have been following the thread with curiosity and interest* – thank you for the great project presentation.
However, I have a question: I probably missed or overlooked it somewhere, but what wall structure did you ultimately choose, and how did you solve the insulation? At some point, if I remember correctly, you mentioned wavering between prefabricated walls and cast-in-place concrete, and that the walls would no longer be insulated in the core because of problems with installing the window units.
I am also debating for my (much smaller) basement build whether we should go with prefabricated walls with core insulation, or what exactly to use for the perimeter insulation.
*And yes, a little bit of envy as well…
rick201813 May 2020 12:41
@Harakiri We mainly use precast concrete hollow core walls. The middle section is then filled with cast-in-place concrete. Additional insulation is applied on the outside. In the areas not located underground, a ventilated facade made of aluminum composite panels is installed in front of the insulation.
