ᐅ Bathroom Installation in a Renovation – Which Finish Plaster to Use in the Bathroom (on Gypsum Board)
Created on: 9 Aug 2012 21:56
coyote_mfr
coyote_mfr
9 Aug 2012 21:56
We are currently installing a bathroom in an older building. The walls were constructed with moisture-resistant drywall panels and properly skim-coated.
Since the house has quite thick exterior walls, the window lintels are shaped in an arch (which I think looks quite attractive). Initially, I planned to tile the walls up to the ceiling, but I wasn’t sure how to handle the arched window lintel in that case.
Now, the plan is no longer to tile the entire wall height (except in the shower). My question is what needs to be considered if the drywall panels are not fully sealed with tiles (including waterproofing slurry, primer, etc. underneath) and instead a fine plaster or similar finish is applied...? Is it okay to simply apply a standard fine plaster on these surfaces?
Thanks.
Regards,
Dieter
O
Orschel
13 Nov 2012 09:23
The cardboard panels should be primed even if a fine plaster finish is going to be applied. We had this done last week, and it looks great!
