ᐅ Are there any ways to make Billy shelves silent?
Created on: 13 Mar 2018 08:12
dirkmar
I have been using several Billy bookcases from IKEA for some time now, which I really appreciate for their design and versatility. However, I am bothered by a problem that many probably know: the shelves creak and squeak under load or even with a light touch, which can be especially annoying at night.
My question is quite specific: Are there practical ways to make Billy bookcases so quiet that the typical creaking and squeaking is significantly reduced or completely eliminated? I am particularly interested in solutions that do not require major modifications or cause lasting damage to the furniture.
Does anyone have experience with special lubricants, damping materials, or modifications that actually reduce the noise? Or is the creaking simply an unavoidable part of this type of construction? I look forward to your tips and opinions!
temeli
14 Mar 2018 13:20
I wanted to give a quick update: The felt strips arrived, and I attached them to the support surfaces last night. The creaking was noticeably quieter right after installation!
I also carefully treated the joints with silicone spray, which was also successful.
I'm really happy that I was able to get the problem under control! Thanks to everyone for the help! 🙂
SUBEN60
15 Mar 2018 08:15
A systematic approach to noise reduction for Billy bookshelves:
1. Check screws and wall plugs and tighten them if necessary.
2. Apply a suitable lubricant to contact surfaces, preferably silicone-based.
3. Attach felt or foam strips to the shelves.
4. Inspect the screws on the back panel, as they contribute to stability.
These measures are reversible, inexpensive, and do not affect the shelf’s functionality.
If problems persist, consider reinforcing the structure with additional connectors.
GIBAPO
15 Mar 2018 09:50
As a supplement to
SUBEN60 schrieb:
systematic approach to noise reduction for Billy shelves
The type and quality of lubricant used are crucial. Silicone spray is better suited than oil-based sprays because it repels dirt and does not become sticky over time.
Additionally, I suggest avoiding unnecessary movement of the shelf while the material is drying and settling, as readjustment can cause creaking.
kogoga
16 Mar 2018 08:35
Alternatively, for a completely silent result, the shelves can be lined with thin felt. Additionally, felt pads on the sides help.
This solution is quick, clean, and reversible.
RON57
16 Mar 2018 11:02
kogoga schrieb:
Alternatively, to achieve a completely silent result, you can line the shelves with thin felt.
Exactly, that makes a lot of sense. In my case, the undersides of the shelves were also lined with felt to reduce squeaking under load. As long as the felt isn’t too thick, the functionality remains unaffected.
