ᐅ Are there upcycling alternatives for old Ikea HEMNES furniture?
Created on: 16 Dec 2021 08:23
Anko61
Anko61
16 Dec 2021 08:23
I am interested in practical and creative upcycling alternatives specifically for old Ikea Hemnes furniture. The series is quite popular, but many pieces look a bit dull after a few years or no longer fit the new interior style. My main focus is on improving the furniture without completely discarding it or just repainting it. I’m wondering if it’s possible to enhance them using other materials or techniques—such as installing different fronts, combining them with natural materials, or integrating modern features.
Has anyone had experience or concrete ideas on how to upcycle HEMNES dressers, display cabinets, or wardrobes beyond the usual sanding and painting? It would be helpful to know how time-consuming this is, what tools are needed, and whether the effort is truly worth it.
Thank you in advance for all the tips and suggestions!
Dirkmin
16 Dec 2021 09:47
Regarding your question about upcycling alternatives for old Ikea HEMNES furniture, I can say that this series is very well suited for such projects due to its solid wood construction. A popular method is replacing the fronts with custom-made panels made from higher-quality hardwoods or MDF with a veneered surface, which gives the piece a completely new look. Additionally, handles are often swapped out for designer or vintage models to create a unique style and break the perception of being “cheap.” Another approach is inlaying veneer or contrasting wood appliqués as decorative elements. For all these options, basic tools such as sandpaper, a drill, screwdrivers, and possibly a router are recommended. The effort involved varies greatly depending on the goal—simple handle replacements take only a few minutes, while elaborate veneering or modifications can take several hours. The stability and reusability of HEMNES furniture generally remain very good.
Henry
16 Dec 2021 12:12
I think it’s great that you are exploring these kinds of upcycling opportunities. Sometimes you have furniture pieces that no longer fit your current style, but you are emotionally attached to them. I once revamped a HEMNES dresser by adding some mosaic tiles – this not only gave the piece a unique look but also created a small ‘wow effect.’ Of course, this requires some patience and a bit of craftsmanship. You should also keep in mind that the original condition often has its own story, and the charm can be lost through drastic changes. So, feel free to try out different ideas and don’t be afraid of making mistakes; that’s part of the creative process.
BENBI
17 Dec 2021 07:36
If you are looking for upcycling alternatives for HEMNES furniture, the exact type of piece and its condition are the first factors to consider. The HEMNES series is made of solid pine wood, which is generally very durable but easier to work with compared to hardwood. A more advanced option would be to completely disassemble the drawer fronts and replace them with oiled or lacquered real wood veneers. This requires precise cutting, preferably with a fine-toothed saw, and possibly some sanding work to achieve a perfect fit. Another possibility is a combination of wood and other materials, such as inserting fiberglass panels or thin metal fronts for contrast. A functional redesign, like installing smart home components, LED lighting inside, or concealed drawer systems, also makes sense if you want to increase the furniture’s value and everyday usability. A small tip: pay close attention to the weight of the new materials because the original fittings are only designed for the expected weight of wood. Fronts that are too heavy can affect stability. Do you already have specific projects or furniture pieces from this series in mind?
klo40
17 Dec 2021 15:58
This thread is very timely—I recently had a similar question and would like to share a brief guide for modifying HEMNES furniture:
First, make sure to sand the surface thoroughly, especially if you plan to change the color, as the original finish is very smooth.
Second, for custom decorative accents, wood putty or moldings can be used as ornaments to achieve a nearly baroque look.
Third, as mentioned, it’s best to change the handles with appropriate drill holes, since HEMNES has standardized dimensions.
Fourth, when experimenting with colors, it’s recommended to use color wax or chalk paints, which cause less damage and preserve the wood grain.
Fifth, for gluing trim or other appliqués, use high-quality wood glue and clamps if necessary. If you have any questions about the correct technique, I’m happy to help.
meoreo
18 Dec 2021 10:04
For simple upcycling, I recommend sanding the fronts, installing new handles, and if necessary, replacing or painting the furniture legs. This way, you can quickly achieve a modern look with minimal effort.
