ᐅ Are there sustainable methods for maintaining Ikea HEMNES furniture?
Created on: 7 Dec 2018 10:27
emirki55Hello everyone,
I’m currently exploring whether there are sustainable methods to care for IKEA Hemnes furniture safely and in an eco-friendly way. Especially with solid wood furniture like the Hemnes series, the question arises how to best protect the surfaces without relying on chemical-based care products that might provide a short-term shine but can harm the material and the environment in the long run.
I’m particularly interested in:
- Which natural or DIY care products have proven effective?
- Are there special techniques to consider during cleaning or treatment to enhance the furniture’s durability?
- How often should care be applied without over-treating or drying out the surfaces?
It is important to me that the methods are not only sustainable but also practical for everyday use. I’m looking forward to your experiences and tips!
Hello emirki55,
First of all, a very important and well-formulated question!
Sustainable care for solid wood furniture is a topic many underestimate. Here is a brief tutorial:
1. Cleaning: Use lukewarm water with a mild, natural detergent (e.g., Castile soap). Important: do not soak the wood, rather wipe with a slightly damp cloth.
2. Drying: Always immediately wipe dry with a soft cloth to prevent swelling.
3. Care: Natural oils like pure linseed oil or beeswax work well. Apply the oil only thinly, possibly with a lint-free cloth.
4. Frequency: Oiling is sufficient 1–2 times a year, cleaning depending on usage monthly.
5. Avoid: Do not use solvents, alcohol, or synthetic polishes.
Common mistakes are over-oiling or cleaning with too much moisture, which damages the wood.
Summary: Patience and less is better than aggressive cleaning. This keeps the surface natural and durable.
In addition to giabau:
The HEMNES series mostly uses painted pine wood. The surface is sealed with a matte clear lacquer that protects against moisture. Therefore, the use of oil on these pieces should be considered more carefully.
On painted furniture, oil can be problematic as it does not absorb properly and may remain sticky. Beeswax-based care products for painted surfaces, especially water-based ones, are often a better choice for sustainable maintenance.
Important:
- Remove dust regularly (dry, soft cloth, microfiber)
- Clean with only a slightly damp cloth
- Do not use abrasive sponges
If the surface becomes matte, special natural-based furniture waxes can help.
Also, avoid strong fading from sunlight exposure, which often preserves durability longer than any maintenance.
Important:
Kyleli schrieb:
For protection, natural linseed oil is suitable, but use it sparingly, otherwise it becomes sticky.Thanks for the tip about the dosage! That actually happened to me recently; I applied too much oil.
giabau schrieb:
Cleaning: Use lukewarm water with a mild, natural cleaner (e.g., Castile soap). Important: do not soak the surface; rather, wipe it with a slightly damp cloth.That sounds sensible. Does anyone know if homemade soap solution based on curd soap can also be used for this?
Laukau5 schrieb:
The HEMNES series usually uses lacquered pine wood. The surface is sealed with a matte clear varnish that protects against moisture. Therefore, oil treatment for these furniture pieces should be considered more carefully.That was very interesting to me, as I had hardly considered the varnish so far. My furniture is indeed lacquered. How does this affect DIY treatments? For example, would oils damage the sealant or is it negligible?
emirki55 schrieb:
Does anyone know if homemade soap solution based on curd soap can also be used for this?Yes, that works well as long as the soap contains no additives. Curd soap is very pure and excellent for gentle cleaning. Just dissolve some curd soap in warm water, dampen lightly, do not soak.
emirki55 schrieb:
What about DIY products then? Would, for example, oils damage the sealant or is that negligible?With lacquered furniture, modern oils usually remain on the surface and hardly penetrate. Incorrect application can cause stains. I recommend specially formulated water-based furniture waxes or polishes without solvents for lacquered furniture, as they do not harm the material. DIY oils should be used only on untreated or oiled wood.
