ᐅ Are there sustainable furniture care products suitable for Ikea Hemnes?
Created on: 11 Nov 2022 08:12
NUJON
NUJON
11 Nov 2022 08:12
I have a rather specific question regarding the care of my Ikea Hemnes furniture. The Hemnes series is mostly made of solid pine or birch with a matte finish, and I would like to know: Are there truly sustainable furniture care products that are specifically suitable for the surface and material of this series? It is important to me that the products are both environmentally friendly and gentle, without damaging the protective layer of the furniture or causing discoloration.
I am also interested in whether conventional oils or waxes might not be recommended for Hemnes furniture due to the type of finish used. I would appreciate concrete product recommendations as well as advice on ingredients to avoid. Perhaps you also have practical experience with DIY care products that can be made sustainably.
Thank you in advance for your insights and tips!
angel
11 Nov 2022 10:27
Hello NUJON,
Regarding your question: Yes, there are definitely sustainable furniture care products suitable for Ikea Hemnes. As you correctly pointed out, the Hemnes series has a lacquer finish that should not be damaged by overly aggressive or oil-based cleaners.
I recommend plant-based care products specifically designed for lacquered furniture, such as wax emulsions containing beeswax or carnauba wax, but without solvents. These products are environmentally friendly, biodegradable, and gentle on the surface.
You should avoid products containing silicones or petrochemical solvents, as they can interact with the lacquer finish and leave visible residues over time.
Another tip: Always test the product first on an inconspicuous area to avoid changes in color or gloss.
If you like, I can provide examples of brands or formulations that I personally recommend.
CHENFAR
11 Nov 2022 12:43
To add to angels’ post:
For painted furniture like the Ikea Hemnes, it is best to use water-based care products. Products with water as the main ingredient and natural emulsifiers are especially sustainable, as they neither release VOCs (volatile organic compounds) nor contain environmentally harmful solvents.
The finish on Hemnes furniture is generally resistant to moisture and light dirt. Therefore, a mild, natural cleaning agent combined with a damp cloth is usually sufficient.
Chemical waxes or oils are less recommended here, as they can cause the painted surface to clump or alter the gloss.
Additionally, regular care using biodegradable microfiber cloths without aggressive scouring agents is a sustainable maintenance practice.
If there are further questions about ingredients, I can gladly provide a brief list of recommended and to-be-avoided substances.
Palenar
12 Nov 2022 09:08
I would like to add some further notes to go deeper into the topic, especially for users who value sustainability and the durability of their furniture.
The finish on Ikea Hemnes furniture is a hard, mostly solvent-based acrylic lacquer layer that protects the raw wood material. This means it is easy to maintain and resistant to moisture. This is good, but the surfaces are sensitive to greasy substances. Therefore, natural waxes, while sustainable, are not always the best choice, especially if they are not specifically formulated for lacquered surfaces. These waxes can darken the finish or make it slightly sticky.
If you want to use a wax-based product, be sure to test it first as angel recommended, since Hemnes is not comparable to oiled solid wood.
An alternative is mild, pH-neutral cleaning and care products that leave no residue (e.g., water-based care gels), which dry quickly after application and do not alter the protective layer. They help maintain the matte appearance and prevent unwanted surface reactions.
In practice, this means:
- Regularly wipe furniture with a soft, dry cloth
- Clean with a slightly damp cloth if needed, not wet
- Prefer special plant-based furniture care products with water-soluble components
Additionally, I am interested in the exact polymer composition used in the Hemnes lacquer – this could help better assess compatibility with certain care products, since not all acrylic lacquers are the same.
If anyone here has more detailed information from Ikea or from independent material tests, that would be very helpful.
jeix9
12 Nov 2022 14:55
Simply use a mild dish soap with water for cleaning, followed by a dry, soft cloth. To protect the painted surface, I do not recommend oils or waxes, as these can cause stains and discoloration.
That is all you need for Ikea Hemnes.
MUMENAR
13 Nov 2022 11:34
jeix9 schrieb:
For protecting the painted surface, I do not recommend oils or waxes, as they can cause stains and discoloration.
I generally agree with this, but I would like to point out that a categorical rejection of all waxes and oils is somewhat oversimplified.
It largely depends on the formulation. Natural waxes, when incorporated in an emulsion designed for painted surfaces, can actually provide protection and enhance water beading without causing discoloration.
Ultimately, the method of application is also crucial: overdosing or too frequent use can indeed have negative effects. Additionally, there are differences in compatibility between semi-matte and matte paints.
Therefore, one should not rely solely on general guidelines but always refer to manufacturer instructions and product testing, ideally with sustainability certifications.
Are there any recommendations from Ikea regarding suitable care products? So far, I have not found any specific information.
