ᐅ Are there storage baskets specifically designed for IKEA PLATSA shelving units?
Created on: 22 May 2018 09:37
Declanle53D
Declanle5322 May 2018 09:37Hello everyone, I am currently organizing my shelving units and came across a specific issue. I have several IKEA PLATSA shelves at home, which are quite flexible and easy to adapt in terms of the basic structure. Now I would like to find out if there are storage baskets or boxes specifically designed for these PLATSA shelves that fit the individual compartment dimensions exactly or are directly recommended by the manufacturer. I am not just interested in general baskets, but specifically those that fit the PLATSA system. Perhaps someone here has good knowledge or practical experience regarding whether IKEA itself offers such products or if other brands have proven to work well? It is also important to me how sturdy and functional these baskets are in terms of material, durability, and how well they integrate into the modular system. Thank you in advance for any tips and advice!
Regarding the question about storage baskets specifically for IKEA PLATSA shelving units, here is what I can say: IKEA currently does not offer any baskets or boxes that are specifically designed and precisely sized for the PLATSA system. The PLATSA system comes with various compartment sizes, which are relatively flexible, but due to this variability, IKEA has so far only sold general storage solutions such as drawers, inserts, or boxes that fit more or less. Alternatively, there are third-party manufacturers on the market producing modular baskets in different sizes; however, these are usually universal products without any system-specific certification for PLATSA. From a practical standpoint, I recommend measuring the internal dimensions of each compartment exactly and searching based on these measurements. When choosing materials, it is advisable to select sturdy fabrics or plastics that can withstand moisture and weight. Stability is just as important for baskets as a good fit to prevent slipping.
Hello, I would like to add: It is true that IKEA does not offer ready-made baskets specifically designed for PLATSA. However, many customers use universal storage baskets that fit the dimensions well and provide a practical solution. Sometimes it also makes sense to use baskets from other IKEA ranges, such as the SKUBB series or similar boxes that fit into the compartments. It is important to consider ease of use and weight, as the baskets should be easy to pull out. When choosing the material, it is also worth thinking about the intended use of the baskets: fabric baskets are lighter but less sturdy than plastic or metal mesh ones. If anyone is interested, I can also offer tips on how to make suitable baskets or inserts yourself using simple methods.
Declanle5322 May 2018 15:42Josan schrieb:
When choosing the material, it’s also worth considering the intended use of the baskets: fabric baskets are lighter but less sturdy compared to plastic or metal wire mesh. Thanks for the tip, that already helps. I was wondering if the PLATSA modules are designed in a way that might allow using drawers or drawer inserts, which could themselves serve as storage.
Has anyone had practical experience with this, for example, whether there are sturdy drawer inserts that actually work well without damaging the carcass too much? I was just unsure because PLATSA is different from the traditional IKEA carcasses and seems to be constructed in a somewhat more subtle way.
Declanle53 schrieb:
I was wondering if the PLATSA modules are designed so that you can possibly use drawers or drawer inserts From an analytical point of view, I would say the PLATSA system is modularly designed to combine different fronts and elements, including doors, drawers, and open compartments. Therefore, IKEA does offer suitable drawer fronts and inner drawers that can be added, but these are usually intended as separate modules by the manufacturer and not simply as basket alternatives.
Your concern about stability is justified, as the PLATSA system relies more on a lightweight and flexible modular construction rather than very sturdy drawer carcasses. Accordingly, care should be taken when loading to avoid permanent deformation.
It is also worth comparing with other systems if durability is a priority. Ultimately, there are no perfect "universal" baskets specifically designed for PLATSA. Instead, you need to check compatibility for your intended use and possibly accept some compromises.
neo59 schrieb:
Accordingly, one should be careful with the load to avoid permanent deformation. Very good point! I always find it interesting how much flexibility PLATSA offers – what’s great is that you can really customize it to your needs, but if you approach it too loosely, it can become wobbly.
Regarding the storage baskets: I personally use a few large fabric baskets from another IKEA series that fit perfectly and are lightweight enough not to add too much weight to the shelving unit. They are not officially designed for PLATSA, but if you know the dimensions, they work really well. Also, the baskets are easy to remove, which is super convenient for organizing.
My advice: Don’t just focus on the look, but also consider usability and weight. It’s better to keep heavier items out of the baskets to avoid overloading the shelf. This way, you can enjoy your PLATSA setup for a long time!
