ᐅ Are there reinforced versions of BILLY shelves available?
Created on: 25 Jan 2022 10:07
jada2
Good morning everyone, I am currently considering purchasing Billy shelves for my office and wondering if IKEA offers reinforced versions of these shelves.
Specifically, I am interested in whether there are BILLY models designed for higher loads or heavier weights, for example with stronger materials, thicker shelves, or additional stability features.
I generally like the standard shelves, but I need a solution that can consistently support more weight without sagging or becoming unstable.
Are there official versions or accessories available to increase their stability? Thanks for your helpful advice!
Benge5
26 Jan 2022 09:40
A brief addition:
The maximum load capacity specified by the manufacturer for Billy is about 15 kg per shelf, which is due to the material quality.
For shelves loaded with 25-30 kg, I definitely recommend using self-reinforced shelves, for example, plywood with a thickness of 18-22 mm (0.7-0.9 inches) plus additional bracing underneath the shelf.
Wall mounting is mandatory to transfer the forces and ensure stability.
This is the only way to guarantee the safety and durability of your BILLY shelves.
jada2
26 Jan 2022 11:08
Benge5 schrieb:
For floors bearing 25–30 kg (55–66 lbs), I definitely recommend using self-reinforced flooring
Perfect, thanks for the clear information. I think I’ll try plywood floors and fix the original shelves to the wall as usual.
It would also be interesting to know if there are official IKEA accessories, such as metal brackets or other reinforcements for BILLY shelves?
KUDAISY
26 Jan 2022 11:42
jada2 schrieb:
whether there are official IKEA accessories that provide, for example, metal brackets or other reinforcements for BILLY
IKEA does not offer specific reinforcement accessories for BILLY. However, you can use universal furniture brackets available at hardware stores. These can be attached to the side panels or the bottom shelves.
Some users also fix metal flat bars to the back of the shelving unit to prevent sagging.
Overall, this is a do-it-yourself solution since IKEA designs the shelf as an affordable system intended for light to moderate household use.
Jodyro
27 Jan 2022 08:57
Briefly addressing your question: Official reinforced versions do not exist for BILLY. For higher loads, I recommend using your own stronger shelves along with wall mounting.
NICOLELIS
27 Jan 2022 09:15
Important to note: Even with reinforced floors, you should distribute the weight evenly. Otherwise, the side wall of the shelf will be damaged.
faso31
27 Jan 2022 22:47
NICOLELIS schrieb:
even with reinforced floors, you should distribute the weight evenly
This is an important point! The central load is often underestimated, which can lead to early failure. Distributing the load properly helps significantly.
