ᐅ Are there reinforced shelves available for Billy bookcases?
Created on: 11 Oct 2022 09:13
CLYDE2
CLYDE2
11 Oct 2022 09:13
I have a question regarding the IKEA Billy shelves and hope to find some expert knowledge here: Are there officially or unofficially reinforced shelves available for the Billy units? Since I want to store relatively heavy books and technical equipment on them, I am looking for solutions that increase the load capacity of the shelves without disproportionately affecting their appearance or functionality.
In case IKEA does not offer original reinforced shelves, I would also appreciate recommendations for alternative materials or instructions on how to reinforce existing shelves. It would be great if someone in the community has experience with the load capacity of the standard shelves and possibly tips on how it depends on the width and depth of the unit.
Thanks in advance for your support!
Alberto51
11 Oct 2022 10:44
CLYDE2 schrieb:
Are there officially or unofficially reinforced shelves for Billy bookcases?
Hi, I think this is a very important question because I often worry that my shelves might sag if I put too many heavy items on them.
I’ve heard that IKEA doesn’t sell specially reinforced shelves themselves, but some people use thicker MDF boards as replacements or install metal brackets underneath. I haven’t tried this myself yet, but it sounds like a good idea.
However, it’s important to remember that the frame of the Billy bookcase also plays a key role in stability. If the entire unit twists or warps, a stronger shelf won’t help much.
Maybe others here can share their experiences? I believe it’s better to be cautious and reinforce the shelves than to be disappointed later if something sags.
farje
11 Oct 2022 11:58
Basically, I would say that the manufacturer IKEA always sets certain limits with heavier loads that should be taken into account.
Alberto51 schrieb:
IKEA itself does not sell any specially reinforced shelves
This also matches my knowledge. As far as I know, officially reinforced shelves are not part of the product range.
What bothers me a bit is the common assumption that you simply need thicker boards or metal brackets underneath. While this helps locally against sagging, the load-bearing capacity also depends on the entire construction. For example, the small dowel holes in Billy bookshelf shelves are a weak point.
Therefore, I would recommend not only reinforcing the shelves but also additionally securing the entire unit with screws or metal profiles for especially heavy loads.
Another question might be: How heavy are the items specifically, and what shelf width are we talking about?
CLYDE2
11 Oct 2022 14:22
farje schrieb:
One question could also be: How heavy are the items exactly, and what shelf width are we talking about?
Thanks for the input, farje! The items usually weigh between 10 and 20 kg (22 to 44 lbs) per shelf, sometimes more. The shelves are typically 80 cm (31.5 inches) wide and about 28 cm (11 inches) deep.
I have considered reinforcing some individual shelves with battens or using plywood instead of the standard particleboard.
It is also important to me that the overall look remains fairly consistent and does not appear to be a makeshift modification afterward.
Has anyone had good experiences with plywood, and are there specific dimensions that should be followed precisely?
sinhau
11 Oct 2022 17:37
Hello CLYDE2,
I find your thoughts on plywood very reasonable, and I would like to briefly explain how to reinforce the shelves without affecting the appearance:
1. Material choice: Plywood is an excellent alternative to conventional particleboard due to its higher density and better bending strength, especially in a thickness of at least 18 mm (0.7 inches).
2. Cutting: The dimensions should match exactly those of the original Billy shelves (usually 80 x 28 cm (31.5 x 11 inches) or 40 x 28 cm (15.7 x 11 inches), depending on the shelf). When cutting the edge, it is advisable to lightly sand the surface and, if necessary, seal it with glue or veneer to protect the wood from moisture.
3. Installation: Plywood panels can be placed on the original support hooks if the thickness is similar. If thicker, you may need to adjust the cover strips.
4. Alternative: If you do not want to use thicker shelf supports, you can also combine a thin plywood panel as a top layer with a hidden metal reinforcement (aluminum or steel profile at the edge or in the center). This way, you avoid visible changes.
Summary: Using 18 mm (0.7 inches) plywood should provide significantly higher load capacity without greatly altering the appearance. Precise work during cutting and installation is the key.
If you like, I can also recommend specific suppliers or DIY guides.
nedagla
12 Oct 2022 08:05
That’s brilliant, sinhau! 🙂
I also have Billy shelves in my living room holding quite heavy equipment. At first, I was worried the shelves would sag, but after switching to plywood, the shelf is really holding up great!
You just have to make sure everything is properly aligned and installed straight. If you can manage that, it’s definitely a top solution.
It also helps a lot to add small brackets under the shelf boards – that way you don’t even notice the reinforcement.
I encourage everyone to try this out, as it really allows you to make full use of the Billy shelf!
