ᐅ Are there reinforced screws available for BILLY shelves to support higher loads?
Created on: 16 Mar 2024 10:23
Meoon60
Hello everyone, I have a question regarding the BILLY shelves from IKEA, which I have been using for years. Since I plan to load these shelves with significantly heavier weights than usual, I am interested to know if there are reinforced or specially suitable screws available for the BILLY shelf series to ensure higher load capacity and stability.
Specifically, I mean the screws used to connect the individual panels and to secure the shelves. So far, my research has only found standard fasteners. Does anyone have experience with stronger screws or alternatives that can be used safely without compromising the safety or integrity of the shelf?
Thanks for your help and tips!
I can understand well that you want to load your shelf more heavily.
From personal experience: for normal use, the original IKEA screws are often sufficient, but they are not designed for very heavy loads.
If you plan to use the shelf with heavy loads over a long period, it can be worthwhile to switch to screws made of higher-quality material. I have used stainless steel screws myself, as my shelf is also placed in a more humid environment. This gives me a greater sense of security and peace of mind.
Also ask yourself whether the load is applied locally or distributed across the surface, as this makes a big difference.
In general: don’t forget to pay close attention to wall mounting!
Meoon60 schrieb:
Is it worth the extra effort to use more expensive screws (e.g., stainless steel or hardened steel)?
Gloriagl1017 Mar 2024 10:05I also equipped my BILLY shelves with more expensive screws, not for load capacity, but for corrosion protection.
There are no officially reinforced screws.
So if you use them for heavier loads, I would recommend more elaborate fastenings and sturdy brackets rather than just thicker screws.
Dopoki schrieb:
Otherwise, metal brackets for reinforcing the internal structure are also usefulThank you, I will check that as well.
I find this topic very interesting because it is often said that BILLY shelves tend to sag over time under heavy weight.
Does anyone have any good tips on how to improve the alignment and stability of the shelves without major modifications?
Or what is the best way to drive screws when they are larger or reinforced, without causing the wood to split?
Maybe someone has experience with pre-drilling or similar methods?
