ᐅ Are there any proven DIY methods to enhance or customize IKEA Metod kitchen cabinets?
Created on: 1 May 2015 08:37
SARA38Hello everyone,
I am currently considering ways to customize and upgrade my IKEA Metod kitchen cabinets to make them look more unique and high-quality. I am especially interested in proven DIY methods to enhance the rather simple design of these cabinets—whether through special paint finishes, installing high-quality hardware, applying decorative films, or even combining them with other materials. It is particularly important to me that the methods are practical to carry out, require relatively limited craftsmanship, and are durable over time without damaging the cabinets or voiding the warranty. Does anyone have experience or recommendations? Which techniques have proven to be especially effective and long-lasting? I would appreciate concrete tips and any advice on common pitfalls to avoid.
Hello SARA38,
Basically, there are some proven methods to enhance IKEA Metod kitchen cabinets very effectively. Here is a summary of the most common techniques:
- Painting: A good primer is essential before painting because the surface is quite smooth. Acrylic paint works best as it is durable and easy to apply.
- Applying adhesive films: Self-adhesive films with wood or metal finishes can quickly upgrade the furniture. It is important that the surface is clean and grease-free to avoid bubbles.
- New handles and fittings: High-quality metal handles or even leather details can create a more sophisticated look.
- Attaching wooden or decorative trim: These can be painted or oiled to create contrast.
For all techniques, make sure to clean the furniture well beforehand and possibly sand lightly to improve adhesion. Regarding the warranty: it usually voids with such modifications, but this is often expected with IKEA furniture when making significant changes.
I hope this helps you already!
SARA38, I completely understand your concern. I experienced something similar a while ago when I wanted to customize my kitchen. The Metod series is really practical, but they don’t look very unique.
I can definitely confirm that. At first, I was unsure if painting would work. But using matte acrylic paint and applying one or two coats gave very good results. It was very important for me not to neglect the edges and to sand them thoroughly first.
I also had good experience with gluing veneered wood panels onto the fronts. This gives the whole thing a very high-quality appearance, feels “real,” and significantly upgraded the kitchen.
Are you up for more work or looking for simpler, quicker solutions?
LUSIN schrieb:
- Painting: A good primer before painting is essential because the surface is quite smooth.
LuMarcel432 May 2015 07:44I would critically question why it always has to be “refined” right away and which materials are being used. Ideally, your modifications should be reasonably ensured in terms of durability and absence of harmful substances. For example, I am not a fan of films that peel off after a short time or get damaged during cleaning. Furthermore, it’s not only a matter of appearance but also of quality and sustainability.
Some DIY guides suggest using laminated wood or decorative panels as front replacements. While this can look genuine, less skilled builders often make mistakes, and the furniture does not necessarily become more durable—often it becomes heavier instead.
So, if you’re thinking long-term, you should either proceed very carefully and methodically or redesign completely. Adjustments like better handles and lighting, on the other hand, create an immediate and noticeable increase in value without risks.
What do you think, SARA38? What matters more to you: a quick visual improvement or a long-term investment?
Sinan-meo2 May 2015 14:53I would like to add that when doing painting work, it is essential to use the correct type of paint and properly prepare the surface. For Metod furniture, water-based acrylic or polyurethane paints are particularly suitable, as they handle moisture well.
Light sanding with sandpaper (grit 220 to 320) is recommended to improve paint adhesion.
When applying films, you can use so-called shrink films, which conform well to edges and reduce bubbles. However, the surface will eventually be affected by kitchen vapors and frequent cleaning, so you should not expect too much durability from films.
My tip: Test your chosen method first on an inconspicuous part or the back panel before working on the entire surface.
