ᐅ Are there magnetic closure solutions available for all Kallax doors?
Created on: 3 Aug 2022 08:37
Fupara
Fupara
3 Aug 2022 08:37
Are there magnetic locking solutions for all Kallax doors?
I’m considering adding doors to my Kallax shelves, but I’ve read that not every Kallax door is originally compatible with a magnetic locking mechanism. I’m particularly interested in whether there are universal magnetic locks that work for all types (such as folding doors, flap doors, and shelf doors), or if you need to buy specific models for each variant. It would also be helpful to know if installing these magnetic locks is straightforward or if the doors or the cabinet frame need to be modified. Does anyone have practical experience or know of good products in this area?
Deandre
3 Aug 2022 09:05
Fupara schrieb:
Are there magnetic fastening solutions for all Kallax doors?
Hello Fupara, that’s a very good and detailed question! Basically, there are magnetic locking systems suitable for several types of Kallax doors, but not all doors are designed for them from the factory. The standard shelf doors usually have a simple push-to-open function or hooking latches; magnetic fasteners are often accessories or retrofit options.
For folding and flap doors, it’s a bit different because with folding doors using hinges, the magnetic lock can be mounted either on the door or on the cabinet frame. There are universal magnetic catches available that can be installed individually.
I recommend checking the measurements and door model carefully before purchase, as many suppliers specify which Kallax variants their magnetic locks fit. Installation is generally straightforward; you just need to align the magnets precisely so the doors close properly. If you like, I can send you a list of reliable magnetic fastening options. 🙂
dosogau
3 Aug 2022 09:47
Deandre schrieb:
Installation is usually straightforward; you just need to ensure the magnets are aligned precisely.
In short: There are magnetic closures that can be used quite universally. Not all doors come with them pre-installed. Retrofitting is possible, but check the dimensions first.
nedagla
4 Aug 2022 11:23
Fupara schrieb:
Are there magnetic closure solutions for all Kallax doors?
It’s great that you’re specifically looking for magnetic closures for Kallax! 🙂
A few months ago, I retrofitted folding doors on my Kallax using magnetic catches that were custom-sized to fit the door dimensions. Installation was really quick, and now the doors close almost automatically and quietly.
One tip: pay close attention to the strength of the magnets! If they’re too weak, the door won’t stay closed; if they’re too strong, opening the door becomes harder. I bought inexpensive sets with different magnet strengths on Amazon to test what works best. For folding doors, there are also special magnetic clip-on types that are very practical.
So yes, there are closures available for many Kallax doors, but it’s not always a one-size-fits-all solution. That makes it interesting – you can really customize your furniture this way!
