ᐅ Are there any Ikea PLATSA models with particularly durable drawers?
Created on: 7 Jul 2020 16:27
bobbysar
bobbysar
7 Jul 2020 16:27
I have a specific question regarding the Ikea PLATSA models: Are there particular models within the PLATSA series where the drawers are considered especially sturdy and durable?
My main concern is stability and load capacity, as I plan to fill the drawers with quite heavy items and open and close them frequently. I know Ikea often uses simple construction methods, but some series seem sturdier than others.
Specifically, I would like to know:
- Are there certain versions or variants of the PLATSA drawers designed to handle more weight and stress?
- Are the drawer slides and runners reinforced or of higher quality compared to standard versions?
- If anyone has experience with a specific combination that proved to be very robust, that would be helpful.
I look forward to your feedback and thank you in advance for the tips!
JAMESONB41
7 Jul 2020 17:03
PLATSA drawers usually do not differ in material. For better load capacity, you should pay attention to the metal drawer slides, which are more durable than plastic runners. The maximum load capacity is normally specified in the product description.
miAlessio
8 Jul 2020 10:49
Hello bobbysar,
To answer your question precisely, it’s useful to have a brief overview of the PLATSA drawer system. Ikea offers different types of drawers for PLATSA, mainly distinguished by the type of drawer slides:
- Standard slides: These are usually plastic rollers or simple metal slides with lower load capacity, more suitable for lighter items.
- Soft-close metal slides: These are sturdier and also allow for quiet closing, reducing mechanical stress.
In your case, you should definitely ensure the drawers have full-extension metal slides, as these are not only more stable but also allow full use of the drawer depth.
Typical load capacities for PLATSA drawers with metal slides are around 10-15 kg (22-33 lbs) per drawer, which is usually sufficient for normal use.
A common mistake is to just choose the cheapest option without paying attention to the type of slide – this directly affects durability.
In conclusion: Yes, there are more robust versions in the PLATSA series that feature soft-close metal slides. Check the product details carefully to confirm if these slides are included.
I hope this helps with your decision!
LENNAU
9 Jul 2020 08:36
miAlessio schrieb:
In your case, you should definitely make sure that the metal drawer slides have full extension, as these are not only more stable but also allow you to use the entire drawer depth.
This is an important point I would like to add: The load capacity of the drawers depends not only on the slides but also on the type of front panel and the stability of the cabinet.
With PLATSA, you can certainly choose a combination of shelves and drawer units where, for example, the drawers have a reinforced back panel. These, together with metal slides, ensure a sturdy construction.
Additionally, I would recommend loading the drawers with an even weight distribution whenever possible, avoiding placing extremely heavy loads in one spot. This also protects the mechanism and extends its lifespan.
If load capacity is very important to you, it might be worth considering purchasing extra drawers with metal sides from Ikea or a combination of PLATSA with other product lines that may offer somewhat more robust constructions.
As miAlessio already mentioned, it is worth considering soft-close and full-extension slides. In practice, these are noticeably more durable and more comfortable to use.
I hope my tips help you!
