ᐅ Are there fully magnetic locking systems available for KALLAX doors?
Created on: 9 Mar 2021 07:43
baansan
I am currently working on a project where I want to add doors to IKEA KALLAX units. I am wondering if there are fully magnetic locking systems for KALLAX doors that operate without mechanical hinges or latches and open and close solely by magnetic force. It is important to me that this solution is both functional and visually discreet, so it does not interfere with the simple style of the KALLAX doors.
Has anyone had experience with such fully magnetic locking systems? Are there any specific products or build guides that achieve this? I would like to know how secure and reliable such a closure is, especially for everyday use. Additionally, I am interested in tips regarding installation and the materials needed.
Thanks in advance for your insights!
sarGabriel
9 Mar 2021 11:58
There are no widely available fully magnetic locks for KALLAX doors that work without mechanical hinges.
Strong neodymium magnets alone are too impractical and cause issues when opening.
Recommendation: Use magnetic bolts as a supplement to hinges. This is a proven method and works reliably.
Tudogo
10 Mar 2021 08:17
FEKAU schrieb:
Magnetic catches alone can be problematic because the magnet strength would need to be very high to reliably keep a door closed
I agree with that.
Here are a few practical tips: fully magnetic locking systems for furniture like KALLAX are quite rare because balancing holding force and opening tension is difficult.
A common compromise is so-called "magnetic latches," which work with a mechanical catch supplemented by magnets.
If a fully magnetic system is absolutely necessary, I recommend using several strong neodymium magnets combined with guide rails or edge guides to keep the door stable while allowing easy opening.
It is important to align the door and cabinet precisely, as even small misalignments can reduce holding power.
If you open the doors frequently in daily use, be sure to test the feel beforehand to ensure the force isn’t too high.
Rensan3
10 Mar 2021 09:03
If you are looking for a simple solution: attach neodymium magnets with a plastic cover on the inside of the door, and mount a steel plate on the frame. This creates an indirect fully magnetic closure that holds securely.
You can adjust the opening force by using different magnet sizes.
