ᐅ Are there differences in stability between the various BILLY model sizes?
Created on: 15 Aug 2022 10:07
Nathanea43
Nathanea43
15 Aug 2022 10:07
Lately, I have been looking closely into the different sizes of IKEA’s BILLY shelves, especially regarding their stability. My question to the community is: Based on experience or technical data, are there differences in stability between the various BILLY model sizes? I am interested not only in static load capacity but also in factors like tipping or warping under everyday conditions.
I understand that different heights and widths create different conditions, but I would like to know, for example, if an 80cm (31.5 inches) wide shelf is more stable than a 40cm (15.7 inches) wide one, or if certain depths are more or less prone to issues. Are there any tips on how to improve stability for larger models? Thanks for your insights and experiences!
Aimee
15 Aug 2022 10:43
Nathanea43 schrieb:
Are there, based on experience or technical evidence, differences in stability among the different BILLY model sizes?
Yes, larger BILLY shelves tend to be more prone to tipping, especially if they are not secured to the wall. Smaller models are more stable because they exert less leverage. Therefore, wall anchoring is essential for large shelves.
retau
15 Aug 2022 12:36
Hello everyone!
I can definitely confirm this, especially with my very wide BILLY bookshelf! 🙂 Without wall mounting, the free-standing shelf actually wobbled noticeably – which was quite uncomfortable. But once secured to the wall, it becomes super stable and feels safe!!!
Also, it seems to help if you distribute the load on the shelves evenly, instead of stacking everything in just one spot.
Aimee schrieb:
Wall mounting is a must for large bookshelves.
That’s exactly what I would recommend, folks! Better to be safe than sorry!
Keep it up, and good luck with your shelves :-)
Blavin
16 Aug 2022 09:14
To add from my side:
Technically, the stability of a shelving unit is fundamentally determined by factors such as height, width, material thickness, fasteners, and the type of mounting. For BILLY shelves, the depth typically ranges between 28 cm and 40 cm (11 inches and 16 inches), the widths are usually 40, 80, or 100 cm (16 inches, 31 inches, or 39 inches), and the heights range from 106 cm to 237 cm (42 inches to 93 inches).
The basic construction is the same, but larger models (especially those with greater width and height) exert more leverage on the wall mounting, making tipping more likely. Without additional reinforcements or wall attachment, the risk of tipping is significantly higher.
It is also interesting that greater depth contributes to lateral stability, as a deeper shelf is less prone to sideways tipping. However, for BILLY shelves with increased depth, the storage capacity suffers from increased warping under heavy load because of a thinner back panel.
Therefore, additional fixings and an even load distribution are always recommended for larger models.
retau schrieb:
The freestanding shelf did noticeably wobble without being attached to the wall
This aligns with the physical principles, especially for tall and wide shelves.
