ᐅ Are there smart retrofit shelves with greater depth available for Kallax units?
Created on: 9 Nov 2017 20:03
mihau
mihau
9 Nov 2017 20:03
I have a question about upgrading my Ikea Kallax shelving system: Are there shelf inserts available that can be cleverly retrofitted and that have a greater depth than the original shelves?
My goal is to increase storage depth without replacing the entire shelving unit. So, I’m not looking for complete shelves with greater depth, but individual shelf inserts that can be installed in the existing Kallax frame.
Does anyone know of such solutions, preferably made from durable materials that are also load-bearing and can be securely fixed? Or are there modifications or tips on how to cleverly extend the Kallax shelves using standard shelf inserts?
I’m open to any suggestions, including DIY solutions or alternative products.
RETRAVIS
9 Nov 2017 20:47
Regarding the question about deeper shelves for Kallax units: Ikea does not offer larger shelves, as the Kallax shelving depth is a standardized 39 cm (15 inches).
A smart upgrade with deeper shelves requires either custom-made or universal shelves that you modify yourself.
One option is simple multiplex boards that you can cut to size individually. Make sure to choose a depth of around 45 cm (18 inches) or more, depending on your needs. For mounting, brackets or metal clips can be used, provided they fit the internal dimensions of the unit and securely support the shelf.
Alternatively, there are third-party suppliers offering modular shelving components with deeper shelf space, but these are rarely available as clip-in shelves for Kallax and are typically designed as replacements or supplements.
dopite
9 Nov 2017 22:11
Here is a structured approach to help you cleverly find shelves for your Kallax:
1. Measure: Carefully measure the interior of the Kallax compartments, especially the depth. The original depth is about 39 cm (15 inches).
2. Material choice: The material should be sturdy and strong, such as 18 mm (¾ inch) thick plywood or MDF.
3. Adjusting the fixing method: The standard shelf supports for Kallax are designed for the original shelves. However, you can use universal shelf supports that can be screwed into or hooked onto the side panels.
4. Alternative fixing options: Metal brackets or special clip systems that are capable of bearing the load well.
Tip: Make sure that the additional shelves do not extend beyond the shelf opening, as this will reduce stability. It’s worth making a sketch beforehand and testing a trial fit if possible.
lubla
9 Nov 2017 22:36
Custom-made shelves made from wooden boards or MDF with a depth of 45cm (18 inches) work well if you adjust the mounting. Use simple brackets or screw-in hooks.
neo59
10 Nov 2017 08:14
RETRAVIS schrieb:
Ikea does not offer larger shelves because the depth of the Kallax unit is standardized at 39 cm (15 inches).
That is true; however, the question remains how practical a deeper shelf is in a cabinet whose entire design and stability are based on this specific depth. A deeper shelf could place additional stress on the side panels and back panel, which may cause long-term issues.
dopite schrieb:
Make sure the additional shelves do not extend beyond the opening of the unit, otherwise stability will be compromised.
Exactly, the ideal solution is to size the shelves so that the overall dimensions of the unit do not compromise its function or stability. Increasing the depth is usually only advisable if the entire structure is adjusted accordingly. Simple retrofits are a compromise that should be assessed carefully.
TuLaurent
10 Nov 2017 13:48
I understand the need for more storage space and have often reached the limits of the Kallax myself. In my experience, increasing the depth is not always the best solution, especially if the shelf isn’t fully enclosed.
Perhaps it helps to combine the existing shelves with additional boxes or baskets that extend deeper and are flexible. This isn’t a modification of the shelves themselves, but a clever way to make better use of the available space.
neo59 schrieb:
A deeper board could put additional stress on the side panels and back panel
I agree, safety comes first, and maximizing flexibility with accessories can often achieve the same result without compromising the structural integrity. 🙂
