ᐅ Are there Billy shelves that are especially suitable for heavy loads?
Created on: 9 Aug 2024 08:34
anganesh
Good morning everyone, I am currently planning to set up a storage room and am considering using several IKEA Billy bookcases for this purpose. My main question is: Are there specific versions or modifications of Billy bookcases that are especially suitable for very heavy loads?
I know that the standard shelves in Billy bookcases have a maximum load capacity, often stated to be around 15-20 kg (33-44 lbs) per shelf. However, since I want to store some heavy equipment and tools, I am looking for more durable solutions or recommendations for reinforcements to keep the shelves stable and safe.
Does anyone have experience with reinforced Billy bookcases or tips on how to use these shelves for heavy loads with relatively little effort? What measures are useful, and where are the limits? Many thanks in advance!
lyndon
10 Aug 2024 08:55
anganesh schrieb:
Are there specific versions or modifications of Billy shelves that are particularly suitable for very heavy loads?
Officially, Billy shelves are not designed for heavy loads. However, much can be achieved with reinforcements. What I recommend:
- Replace the standard shelves with thicker boards (e.g., 19mm (3/4 inch) plywood).
- Use additional aluminum or steel profiles as support underneath.
- Check the attachment points of the wall anchors, securing them into load-bearing elements of the wall (plaster alone is not sufficient).
Even reinforced shelves have load limits, but about 40 kg (88 lbs) per shelf can be supported without major issues.
gregto
10 Aug 2024 11:47
Regarding the topic "Are there Billy shelves that are particularly suitable for heavy loads?" I would like to add the following:
The shelves sold by IKEA are generally designed for light to medium loads (about 15 kg per shelf) (approximately 33 pounds). Heavier loads require a customized approach:
- Reinforcing the shelves with stronger plywood or multiplex boards.
- Using metal profiles as supporting middle beams.
- Careful and secure wall mounting, ideally into load-bearing walls or using appropriate anchors.
- Structural considerations: The taller the shelf and the heavier the load, the more important stability in all directions becomes.
Anyone regularly storing up to 40 kg or more per shelf (about 88 pounds) should consider combining these measures and ensure a stable base.
Additionally, professional heavy-duty shelves could be a better solution if the loads need to be distributed evenly across multiple shelves.
anganesh
10 Aug 2024 13:16
gregto schrieb:
The shelves sold by IKEA are designed by default for lighter to medium loads (around 15 kg per shelf) (about 33 pounds per shelf).
Thank you for confirming, I was already aware of that. I am especially interested in whether anyone has practical experience with the mentioned reinforcements – for example, using metal profiles or replacing the shelves.
Are there differences in handling or effort? How stable does the shelving unit prove to be in everyday use, and are there any known weak points? It is particularly important to me that the stability is not only theoretical but also proven over long-term use.
tra_nina
11 Aug 2024 07:58
anganesh schrieb:
Are there differences in handling or effort involved?
Yes, definitely. Replacing the shelves with plywood panels requires a bit more effort, as the panels need to be cut precisely. However, the result is very sturdy and looks solid. Installing metal profiles requires additional craftsmanship and tools but is often the most effective reinforcement against sagging.
In the long term, the weak points are usually the attachments to the wall and the connections between the shelf parts. I would rely on regular inspection of these components.
If you plan to move the shelf frequently, metal profiles can be somewhat inconvenient, but they are ideal for a fixed position.
