A few months ago, I bought and assembled a Billy bookcase from IKEA. At first, everything was fine, but over time the bookcase has warped noticeably, so the shelves no longer sit at right angles and the whole structure feels unstable.
My question is: Why does my BILLY bookcase warp after some time?
The bookcase is placed against an exterior wall, not directly by a window, but in a room with somewhat fluctuating humidity. All the shelves were installed according to the instructions, and I haven’t placed any heavy or unevenly distributed loads on it.
Could this be related to the material, or is it more likely caused by environmental factors? Are there ways to prevent the warping or to fix it afterward?
I look forward to your insights and advice!
Hey posoni,
I would say that with Billy shelves, this is a little mystery that everyone experiences at some point. But seriously: since the shelves are made of fairly thin chipboard, they behave like wood and can expand or contract slightly with changes in humidity.
My tip: don’t place the shelf too close to a radiator or a window where drafts can affect it. And if you want to upgrade, get some colorful brackets – they look good and also help stabilize the whole thing.
Exactly, that’s the right approach and also quite affordable.
Good luck! 🙂
tyson51 schrieb:
Small sturdy metal brackets from the hardware store are better
Good luck! 🙂
Wesley schrieb:
colorful brackets – they also look greatExactly! You can even make it look stylish if you want to 😎
But seriously: Warping is largely caused by humidity, as has been mentioned several times. A tip from me: Leave the doors of the shelving unit open for a few days at the beginning so the wood can adjust to the room’s atmosphere.
If you assemble the shelf in a new, freshly renovated space, this can be especially helpful because the room still holds a lot of moisture.
Small changes like this often work very well alongside reinforcements. 🙂
To provide a factual conclusion on the topic:
The materials used for the BILLY shelves often consist of medium-density fiberboard (MDF) or particleboard. These materials are sensitive to moisture because they are hygroscopic, meaning they absorb moisture from the air.
Important for durability:
- Location choice: Keep away from damp rooms and heating elements.
- Assembly: Ensure secure, square positioning with tight connections.
- Reinforcement: Additional brackets securely connect the side panels to the shelves.
Warping is a physical process that cannot be completely avoided, but the measures mentioned can significantly reduce its occurrence.
Siflo schrieb:
Warping is a physical process that cannot be completely avoided but can be significantly reduced by the measures mentioned.Thank you, that is an important point for me. That way, I can set realistic expectations.
tyson51 schrieb:
Screws that do not leave large holes in the particleboardHow sensitive is the material in that regard? I am concerned that using screws that are too large might cause it to tear out.
Does anyone have experience with alternative methods, such as wood glue combined with screws or dowels?
anfeteo schrieb:
replacing the back panel with a stable, thin multiplex plywood board works wondersSounds good, but it seems like a bigger project. Is that feasible within a reasonable effort?
posoni schrieb:
How sensitive is the material there? I’m worried it might tear out with screws that are too large.Good question. Particleboard can indeed tear out around screw holes, especially if the screws are too thick or too long and the boards are thin. This then leads to localized weakening and even more warping.
Therefore, the choice of screws is crucial: short, thin screws with fine threads work better – ideally, special particleboard screws.
posoni schrieb:
Has anyone tried alternative methods, for example wood glue combined with screws or dowels?Wood glue alone usually doesn’t help much, since many particleboards don’t have real wood fibers to bond. Dowels only work for very sturdy parts and are generally impractical for thin shelf sides.
Replacing the back panel with plywood is definitely a bigger task, but if you have some DIY skills, anyone can manage it with a bit of time. It provides significantly more stability and prevents warping in the long term.
It’s an investment in the shelf’s durability.
Hector schrieb:
Chipboard can tear out around screw holesThat’s absolutely correct. To prevent this, you can pre-drill holes slightly smaller than the screw diameter.
Wood glue works best when using solid wood panels. With the BILLY shelf, this often isn’t the case, so relying solely on glue is risky.
If you consider a plywood back panel as an "upgrade," I can only agree. It requires some extra effort but is a good way to increase both stability and longevity.
Best regards!
