ᐅ Are there any tips regarding the load capacity of the shelves in Ikea Pax wardrobes?
Created on: 14 Aug 2022 08:37
Jukarl1
Jukarl1
14 Aug 2022 08:37
I have a detailed question regarding the load capacity of the shelves in the Ikea Pax wardrobe system. It is important for me to know how much weight each shelf can support without bending or being damaged. I am particularly interested in whether there are differences depending on the materials and shelf depths, as Ikea offers various options. It would also be helpful to know if there are official specifications from Ikea, and which additional measures (such as reinforcements or extra support rails) have proven effective to increase stability under heavy loads. Who has experience or reliable data on this? Thank you in advance!
Kukar
14 Aug 2022 09:12
The standard shelves of Pax can support about 20 kg (44 lbs) per shelf. If you need to carry more weight, you can add additional middle supports or switch to stronger materials.
Palenar
14 Aug 2022 10:05
Regarding your question about the load capacity of the shelves in the Ikea Pax system: there are indeed some important points to consider. First, the standard shelves are usually made of particle board with a laminate layer. These are stable but have limited load capacities, which Ikea states to be about 20 kilograms (44 pounds).
Although the shelf depth (commonly 35 cm (14 inches), 58 cm (23 inches), or 63 cm (25 inches)) affects the visible storage space, it also plays a crucial role in load-bearing capacity, as longer spans lead to greater deflection. Technically, a board with a depth of 60 cm (24 inches) will bend significantly more under the same load than a 35 cm (14 inches) board.
If you plan to store heavy items, you might consider the following options:
- Installing additional metal supports or center posts to reduce bending
- Adding extra shelves or individual cross braces
- Buying or selling more durable shelves, possibly made from MDF or plywood
Are there specific loads and use cases you have planned for your wardrobe? That would help provide more targeted advice.
gilen
15 Aug 2022 08:49
Palenar schrieb:
First of all: Standard shelves are usually made of particleboard with a laminated surface. They are sturdy but have limited load capacities, which Ikea specifies as about 20 kilograms (44 pounds).
That sums it up very well. I would add that when it comes to Pax shelves in particular, it is important to ensure correct assembly since incorrectly inserted metal clips or missing supports can significantly affect stability.
From my experience, I also recommend not stacking very heavy items like full boxes of books on single shelves but rather distributing the weight across multiple levels. If you have to store heavy loads, you might consider using so-called “shelf reinforcements” from Ikea – these are inexpensive and really help extend the lifespan of your cabinet.
One more tip: if you want to store very heavy items, it’s also wise not to place the weight directly on the shelves but as close as possible to the side or middle panels, as these areas provide higher load-bearing capacity.
Genevieve
16 Aug 2022 12:23
I find the topic of official information from Ikea regarding load capacity very interesting. Are there reliable data from tests or official documentation showing how much weight the standardized Pax shelves can hold?
Jukarl1 schrieb:
It would also be helpful to know if there are official statements from Ikea and what additional measures (such as reinforcements or extra support profiles) have proven effective
Many users often report sagging or instability, which naturally also depends on actual usage and external factors. From a technical perspective, I wonder how much leeway Ikea allows in their load specifications and whether there is a safety margin when the shelves are fully loaded.
It is also important to consider not only static but also dynamic loads—for example, when loading and unloading or during short impacts.
What experiences have others had with this? Do you use specialized reinforcements or accessories beyond the original parts? Are there any recommendations for replacing the standard shelves with more robust alternatives?
Naomige
16 Aug 2022 15:57
Genevieve schrieb:
Are there reliable test data or official documentation that prove how much weight the standardized Pax shelves can hold?
Ikea does state that the standard shelves can support about 20 kilograms (44 pounds), with some deeper versions holding up to 25 kg (55 lbs). This information is also available on the product packaging or on the website.
The stronger shelves (e.g., made from MDF or reinforced with metal) can support between 30 and 40 kg (66 to 88 lbs).
In my experience, with a 63 cm (25 inch) deep Pax unit, I have placed around 15 to 20 kg (33 to 44 lbs) on each shelf—when assembled carefully, this is stable.
To reinforce the shelves, I sometimes add extra metal brackets underneath the shelves when heavier loads are expected—this noticeably reduces sagging.
What also helps is distributing the weight as evenly as possible over multiple points. When the shelves are loaded evenly, the overall stability is much better.
