ᐅ Are there any tips for childproofing IKEA Besta cabinet doors?
Created on: 28 Oct 2016 20:14
O
ottotauHello everyone, I am looking for practical tips and solutions to childproof the doors of my IKEA Besta cabinets. The doors are made of wood and are relatively easy to open, which my curious little one frequently takes advantage of. I would prefer suggestions that can be implemented without major modifications, are as discreet as possible, but above all secure and durable. Does anyone have experience with child safety locks or special latches for these doors? I am particularly interested in proven products or DIY methods that work well with Besta doors and avoid common issues like surface scratches or difficult installation. I appreciate any advice!
Hello ottotau,
You have raised a very good question because locking IKEA Besta doors is not straightforward if you want to maintain the original appearance and avoid damage. Here is a somewhat detailed overview:
- First of all, it is important to know whether your doors have routed edges or are simply flat. This significantly affects the choice of child safety locks.
- Mechanical locks or latches installed on the inside are often the best option, as they are hardly visible from the outside and relatively secure.
- Magnetic locks offer an "invisible" solution but require precise installation and work well only if the door closes flush.
- A classic solution is latches mounted at the bottom or top of the doors. For Besta doors, those that require a screwdriver to open—so not just by hand—work best.
Problems I noticed during my research: cheap plastic locks tend to break after a short time, whereas metal latches often scratch the door or cabinet frame if they do not fit exactly.
Therefore, my tip: first consider how often you need to open the doors yourself. If only occasionally, a small screw latch can work very well—functioning almost like a padlock. For installation, it is advisable to test the position multiple times with masking tape.
Finally, a question for you: Are your doors flush-mounted, or is the cabinet placed in a niche with little space? This affects which locking mechanism is practical to install.
I have also tried some examples at home; if you are interested, I can provide more detailed information about specific products or custom solutions.
PIN66 schrieb:
Cheap plastic locks can break after a short timeI agree with that, but I would add: How reliable are these locks really? Many child safety locks can be bypassed with minimal effort if you look closely.
Basically, I’m skeptical whether standard child safety devices can permanently stop a clever toddler.
Are there any experiences with how multiple systems work together? For example, magnetic locks plus mechanical latches? Or is that overkill? Maybe aiming for too much safety can be self-defeating if it makes handling too complicated.
I think it’s important to ensure parents don’t make everyday life harder with complicated safety measures. In the end, a combination of structural measures and education is probably the best approach.
Hey ottotau and everyone else!
I can only say: there are great solutions to really make your doors childproof – you can do it! Especially with IKEA Besta cabinets, I’ve had excellent experience with magnetic locks that are hardly visible because they are hidden inside. And if you add a small mechanical latch as well, you get double security.
Don’t get discouraged, it works very well. And remember: the effort is worth it – little ones often try to help even when they’re not supposed to. Safety is a real plus there. Have fun building and installing!
