ᐅ Are there any tips for assembling Ikea Pax wardrobes without assembly assistance?
Created on: 7 Sep 2023 18:23
fufimin
fufimin
7 Sep 2023 18:23
Hello everyone, I plan to assemble an Ikea Pax wardrobe entirely by myself without professional help, as I want to save on those costs and enjoy doing it on my own. I have a question: Are there any specific tips or tricks for assembling the Pax system that make the process significantly easier or help avoid common pitfalls? I do have some experience with furniture assembly, but the Pax system seems to be on a different level due to its size and complexity. It would be great if you could share practical advice that goes beyond the included instructions. For example, how to best handle the heavy parts, how to correctly adjust the wardrobe components, and if there are particular sequences or tools that are especially useful. Thanks in advance!
labar43
7 Sep 2023 19:45
Hey, great that you’re taking on the Pax yourself! 😊 My most important advice: definitely give yourself plenty of time and, if possible, get someone to help you. The wardrobe can be assembled solo, but it’s much easier and faster with a partner! Having an extra pair of eyes to check alignment will save you a lot of frustration later on. One more thing: before you start building, check all parts and screws to make sure nothing is missing. I’ve read that the base of the wardrobe can sometimes warp slightly at first—so make sure it’s lying completely flat! Good luck, it will turn out great!
Gafiel
8 Sep 2023 09:17
Hello, I would like to expand on the topic and add some technical details about assembling the Pax system, as mistakes often occur during installation without professionals. First, it is crucial to ensure the mounting surface is completely level – this forms the foundation for a straight cabinet. Unevenness can later cause doors to wobble or cabinet frames to warp. Second, when assembling, do not nail the back panel immediately; instead, attach it at the end. While it contributes to overall stability, the structure must remain flexible during alignment. Another important aspect is the order of screwing: always start with the cabinet walls, and make sure to use a cordless drill with torque control to avoid overtightening the screws and damaging the material. Finally, I recommend installing and carefully adjusting the door hinges and drawer runners only at the very end. A quick tip: if you don’t fully tighten the included expansion plugs in the screws right away, you can adjust them more easily later. I’d like to know: Are you planning a simple configuration, or do you want to connect multiple sections?
fufimin
8 Sep 2023 10:04
Gafiel schrieb:
What I would like to know: Are you planning a rather simple configuration or do you want to connect multiple sections?
Thanks for the detailed answer! I’m planning a fairly large wardrobe unit consisting of three sections that will be connected. I definitely want a connection that is as stable as possible since the unit will bear quite a lot of weight. I’m especially concerned about accurately aligning the doors, which in this case are a mix of glass and wood from Pax. Is there a trick to mounting the doors so they sit flush and with no gaps, even if the floor isn’t perfectly level? And regarding the cordless drill – I have one with adjustable torque, but I don’t have much experience with it yet. Should I start with a lower torque setting?
kaubi
8 Sep 2023 14:31
Regarding your questions about the large wardrobe and the doors: This is a common challenge that can even cause experienced DIYers to sweat. Important tip: If the floor is not completely level, use the adjustable foot system from Pax – there are adjustable feet at the bottom of the side panels that you can fine-tune until the frame is perfectly upright. It’s also a good idea to have a spirit level on hand and proceed very systematically, step by step.
When adjusting the doors, it helps to first roughly position the hanging screws, then align everything, and finally tighten the screws. The hinges have three adjustment screws: one for height, one for depth, and one for lateral alignment – test each one individually and make small adjustments. It’s normal for doors to fit perfectly only after several attempts at adjustment.
Regarding the cordless drill: Exactly right, use the lowest torque setting. If you screw too hard, you risk damaging the wood or stripping the screw socket. I always do a test first in an inconspicuous area with the torque setting.
If you need specific recommendations on the sequence for assembling and connecting the sections, just let me know!
te-min
8 Sep 2023 15:07
Summary of the key tips: - Use adjustable feet to compensate for uneven floors - Install door hinges loosely at first, then adjust them - Use a cordless drill with low torque - Attach the back panel only at the end - Check all parts before assembly I think this covers the main points well.
