I’m moving into a new rental apartment soon and am considering furnishing most of it with IKEA Platsa series furniture. I really like the flexibility and modularity of the Platsa furniture, as I plan to possibly adjust the setup and take it with me in case of a future move. However, I’m wondering if this furniture is generally suitable for rental apartments—especially regarding stability, assembly and disassembly, as well as everyday durability.
I’m also interested in whether there could be issues with landlords if, for example, wall-mounted cabinets need to be attached directly to the walls or modified. Does anyone have long-term experience or practical tips from the perspective of living in a rental?
I look forward to your assessments and specific experiences, thank you!
Hello Ba_bo,
your question is very well thought out, and I think it’s important to consider the specific aspects of rental apartments when choosing furniture.
IKEA Platsa is known for its modular design, which makes it relatively easy to disassemble and reassemble the furniture when moving – ideal for tenants who want to stay flexible. The stability is generally sufficient for normal household use: the construction combines wood-based materials with metal frames, giving the furniture solid stability in most cases.
However, proper assembly is crucial: if you want to fix the furniture to the wall, you should be careful not to cause any damage to the rental property. Many landlords are sensitive to improper drilling and anchoring. You could try using non-slip mats or self-adhesive brackets if drilling is not allowed.
Another tip: the Platsa series offers both open and closed modules that you can combine well without extensive wall mounting. This allows for flexible arrangements and the load capacity is good as long as you don’t overload them.
If you need more detailed instructions, I’m happy to help!
I love the Platsa furniture! 😊 I used it myself in my first rental apartment and was impressed by how flexible it is. You can easily modify or expand individual pieces when the space changes. The assembly is a bit fiddly, but it’s very practical when moving.
And honestly: For rental apartments, I think the combination of price, design, and adaptability is just perfect. Just don’t overload it and pay attention to the maximum load capacity, then it works wonderfully! So, go for it!
Kolepau schrieb:
I love the Platsa furniture! 😊 I used it myself in my first rental apartment and was amazed by how flexible it is.That is certainly a positive experience, but I would like to add a more critical perspective: How stable is this furniture really under heavier loads or after prolonged use? Platsa is rather an affordable system made with particleboard and metal frames – what happens with frequent disassembly and reassembly?
Additionally, I recommend consulting the landlord before attaching anything to the walls. Some rental agreements prohibit alterations to the walls. This can potentially lead to unnecessary conflicts.
Furthermore, I would be interested to know if there are experiences with increased weight loads (e.g., many books or dishes) – since modular furniture often has different weight limits compared to solid cabinets.
Ba_bo schrieb:
I am moving into a new rental apartment soon and am considering furnishing most of it with IKEA Platsa series furniture.Here are some practical tips related to your initial question:
- The Platsa furniture is well suited as a furniture solution for rental apartments because it is easy to assemble and disassemble when needed, which simplifies moving.
- The stability is adequate for everyday residential use; however, avoid stacking excessive weight on individual units.
- Wall mounting is possible, but in rental apartments, you should carefully check the condition of the walls and obtain the landlord’s permission to prevent repair costs when moving out.
My advice: Plan ahead for disassembly as well—that is, consider how much effort it will take to take the furniture with you if you move again. The Platsa series offers advantages in this regard compared to more expensive built-in wardrobes.
