ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
face2622 Feb 2021 19:45
Bookstar schrieb:
It's freezing cold here again, so the heating is still running hard...
Where is it so "freezing cold" right now?
Are you in some kind of cold spot?
halmi
22 Feb 2021 20:43
We have slightly lowered our heating curve. Otherwise, it gets a bit warm after 10 hours of sun, but at the moment we don’t want to block out the sun.
tomtom7922 Feb 2021 20:49
Which value did you change?
@Alessandro then I confused you with someone else.
halmi
22 Feb 2021 21:20
I changed from 25-22 to 24.5-21.5
Bookstar
22 Feb 2021 21:23
face26 schrieb:
Where is it currently "freezing cold"?
Are you in some kind of cold spot??
At night 0°C (32°F) and during the day below 10°C (50°F). No idea what's going on here, I only read 20°C (68°F) every day in the weather report 😀
Bookstar
25 Feb 2021 10:33
Here’s an update from me again 🙂
Over the past 10 days, we have averaged a heat output of 80 kWh and an electricity consumption of 19 kWh per day. This means the heat pump is operating with a coefficient of performance of about 1:4, which seems pretty good.
To reduce the heat output even further, I lowered the heating curve by 2 degrees. Currently, due to the sun, we have the issue of needing to ventilate a lot during the day to avoid overheating (with outside temperatures around 30°C (86°F), the windows are almost always open), while at night, when it drops to 0°C (32°F), the heating runs again.
I hope the lower heating curve will help balance this effect since the sun warms the rooms sufficiently in the morning.
We’ll see if it works and saves electricity 🙂
