I need to install three walk-in showers, each about 1.20 meters (4 feet) long and approximately 0.9 to 0.95 meters (3 to 3.1 feet) wide, with shower glass. Most of the frames I have seen are chrome or black. There aren’t many white ones. At school, I saw a white frame, but the glass was only 6mm (1/4 inch) thick.
1. Is 6mm (1/4 inch) still acceptable, considering most shower glass I’ve seen is between 8 and 10mm (5/16 and 3/8 inch) thick?
2. Instead of long frames, there are sometimes two wall brackets used. Would such brackets be recommended? Could it be possible to use two stabilizing bars instead of frame/bracket and have the glass “freestanding”?
netzplan schrieb:
1. Is 6mm still okay, considering most shower glass I have seen is between 8 and 10mm?I’m not comfortable with 6mm. I usually go with 8mm.netzplan schrieb:
2- Instead of the long profiles, there are also sometimes two wall brackets. Would those brackets be recommended? Could you maybe use two support bars instead of profile/bracket and have the glass "free-standing"?I find those things really unattractive. They’re never as watertight as the long profiles, although they hold just as well. How you would seal free-standing glass (just held by bars) is beyond me. Stability also suffers — if someone leans on the glass near the bottom, in the worst case, the shower panel could be pushed inward (the glass usually just rests on the floor, without a threshold or guide rail). You could also use profiles that are flush-mounted into the wall. That way, you get the same look with guaranteed secure fixing and a watertight wall connection.Hey @nordanney
Thank you very much for the detailed response. I will go with at least 8mm (0.3 inches) then. (Although Schulte isn’t exactly a no-name brand and their 6mm (0.2 inches) option is probably an entry-level quality).
Regarding flush-mounted: When I search on Google, the shower glass panels with two fittings (top and bottom) mainly appear. Geberit offers something where the rail can be recessed into the wall.
