ᐅ Interpreting the zoning plan / Is it even feasible to implement?
Created on: 11 Apr 2022 21:56
E
Eden1812
According to the development plan, a house with 1.5 floors, a gable roof with a pitch of 24-27 degrees, and no knee wall is permitted. We are wondering how this is supposed to work. Does anyone have experience with this and a solution to offer? We actually want to build a prefabricated house, not an architect-designed house (due to cost certainty).
E
Eden1812
13 Apr 2022 15:15
Keep writing anyway.
The surrounding buildings can be seen from the outside: ground floor and attic floor, without knee walls. Whether there are basements is unknown. There is one house with a dormer window. Otherwise, there is a house with a ground floor at basement level and an upper floor, then a roof without knee walls.
The plot is slightly sloped. The gradient is currently unknown. However, in my opinion, it is not steep.
WilderSueden
13 Apr 2022 15:20
Can you get a plan with an elevation profile? If not, get a water level hose and measure it yourself, or talk to the neighbors to see what they know.
Eyeballing it is just unreliable when it comes to height differences. My plot has a 2-meter (6.6 feet) difference diagonally. When you're standing on it, it doesn't look like that at all, more like 70cm (28 inches).
gutentag13 Apr 2022 16:31
It should also be clear from where the measurements are taken.
Yes, from the planned terrain. That’s quite reasonable.
gutentag13 Apr 2022 16:40
Eden1812 schrieb:
Otherwise, a house with a ground floor in the basement level and an upper floor, then a roof without knee walls.
The plot is slightly sloped. Gradient currently unknown. However, in my opinion, it is not steep.
The red and blue don’t quite match. But it is quite common to build like this with two full storeys on a slope (basement + ground floor + roof). It would also comply with the building regulations / planning permission.
At least now you have a usable statement.
That was really a difficult process.
gutentag13 Apr 2022 16:47
WilderSueden schrieb:
Can you get a plan with an elevation profile? If not, get a water level hose and measure it yourself, or ask the neighbors what they know.
Estimating by eye is just unreliable when it comes to height differences. My plot has a 2 m (6.6 ft) difference diagonally. When you stand on it, it absolutely doesn’t look like that, more like 70 cm (28 inches).
You can easily find that on the BayernAtlas with an accuracy of 0.1 m (4 inches).
@Eden1812 Is there no geoportal available in your area?
13 Apr 2022 18:19
If the development plan indicates a U shape and a layperson mentions that there is a slope, but not a steep one, you can assume that there is enough of a slope to make building a simple bungalow on a slab foundation difficult. It is better to plan with a basement in this case.
-> This will not be a cheap build, nor comparable to building on flat land.
I hope this partly answers your question?!
