ᐅ Single-family house floor plan, approximately 150-160 sqm on a 480 sqm plot in Middle Franconia
Created on: 18 Mar 2022 00:49
RufusJWB
Hello!
Here are our initial thoughts regarding our single-family home. I would greatly appreciate your comments (including critical ones). I will try to answer all questions promptly.
Plot size: 481 sqm (5180 sq ft)
Slope: none
Building coverage ratio: 0.4
Floor area ratio: none
Building window, building line, and boundary: approx. 19 m (62 ft) (north-south) x 24 m (79 ft) (east-west), see cadastral map
Edge development: only carport / garage
Number of floors: 2 + pitched roof
Roof shape: pitched, flat, shed
Design style: none specified
Orientation: none specified
Maximum heights / limits: gable 9 m (30 ft), eaves 6.5 m (21 ft)
Other requirements: none
Design style, roof shape, building type: modern / Franconian, pitched or shed roof
Basement, floors: yes, ground floor + upper floor
Number of occupants, ages: 4 persons, 2 adults, 2 children aged 1 and 4
Space requirements on ground and upper floors: see room program
Office: family use or home office? Home office & music room (for music teacher) (see room program)
Number of overnight guests per year: typically 1-2, up to 4
Number of dining seats: 4 (6)
Fireplace: preferably yes, possibly as pellet stove in the living room
Music / stereo wall: not necessary
Garage, carport: carport in front of the house
Other wishes / special features / daily routine, also reasons why some things should or should not be included: The music room should become part of the living room when not used for teaching, as the piano is located there.
Who created the design:
- Architect: many inspirations from picture books
- Do-it-yourself: and then supplemented by us according to our needs
What do you particularly like? Why? The open and transparent architecture on the ground floor, the clear southern orientation
What do you not like? Why? Perhaps it is a bit too small, so we might make it one meter longer. We can only fit the home office & guest room in the basement.
Price estimate according to architect/planner: We told the construction company a limit of 500,000 € for the house, and so far there has been no rejection. We do not have any firm offers yet.
Personal price limit for the house, including equipment: 550,000 € + carport + utility connections + etc. → max. 700,000 €
Preferred heating system: pellet stove or heat pump
--> Perhaps a quarter-turn staircase would be better, as it would provide additional space for the music room on the ground floor and allow the play area upstairs to be separated from the staircase by a railing.
--> The basement is still not fully planned.
If you have to give up any details / expansions:
- you can do without: the design is already very simple; if necessary, the guest bathroom in the basement and the kitchen island. An L-shaped kitchen would probably also work.
- you cannot do without: the music room and the WC on the ground floor.
Why has the design turned out the way it is? For example:
Which wishes from the architect have been implemented? --> The construction company’s planners have difficulty implementing our ideas.
A mix of many examples from various magazines? --> Yes
What do you consider particularly good or bad about it? --> The open architecture on the ground floor and the (almost) equally sized rooms upstairs.
What is your constructive critical opinion of our design? What would you do differently?
Room program:
Ground floor
Kitchen
Dining room (ideally with direct access to the kitchen)
Living room (with seamless transition to the dining room)
Music room (with a large sliding door to the living room; when open, it becomes part of the living room; direct access from hallway)
Hallway
Guest / student toilet
Basement
Utility / technical room
Storage / laundry room
Guest room
Guest bathroom
Home office
Upper floor
Children’s rooms 1 & 2
Master bedroom
Family bathroom
Outdoor spaces
Carport
Garden shed / storage shed
Waste container shelter
Floor plan of a house: kitchen with island, living room, hallway, bathroom, WC, staircase on the right.
Site plan of a plot with red marking at the bottom of the image; continuation certificate 809 03 Heßdorf.
Hand-drawn floor plan of the attic with bathroom, hallway, and rooms.
gutentag19 Mar 2022 17:12
Here is the template based on the original poster’s information.
Floor plan of a house with open living/dining/kitchen area, hallway, pantry, restroom.
Floor plan of a single-family house with bathroom, corridor, bedroom, and children’s room
Is the exterior wall measured as 35 cm (14 inches)?
Short side according to the manufacturer is 8.20 m (27 feet) exterior
SoL
19 Mar 2022 17:12
However, with a basement for living space, the 550k budget will most likely be exceeded...
gutentag19 Mar 2022 17:26
SoL schrieb:
This includes a basement living space, so the $550k budget will almost certainly be exceeded...
The house provider is planning an extension. But it won’t come for free either.
Floor plan of a living, dining, and kitchen area with hallway, toilet, pantry, and stairs
@RufusJWB Is there a building permit / planning permission? Where are the parking spaces supposed to go?
gutentag19 Mar 2022 17:41
According to BYA, the plot is approximately 21 m (69 feet) wide. WO, where do you get the 18.5 m (61 feet) from? Slope towards the north is 1 m (3 feet), slight incline.
SoL
19 Mar 2022 17:41
gutentag schrieb:
The house provider is planning an extension. But it's not free of charge.
[ATTACH alt="Grundriss109.JPG"]70402[/ATTACH]
@RufusJWB is there a development plan / planning permission? Where are the parking spaces supposed to go?
House provider or not, the original poster wants to put the utility room, an office, and a guest room in the basement...
gutentag19 Mar 2022 17:49
SoL schrieb:
Regardless of the house supplier, the original poster wants to put the utility room, an office, and a guest room in the basement...
I wouldn’t recommend including a basement, especially not with that budget.
There is a parking space regulation by the municipality. What does it specify?
