ᐅ NRW – Terrace Renovation with Partial Glazing
Created on: 2 Nov 2021 11:08
Member87
Member87
2 Nov 2021 11:08
Hello community,
I have a terrace roof covering about 45m² (480 sq ft).
For this, I have a building permit including structural calculations, etc.
Now I am planning to glaze part of the terrace and convert it into a kind of conservatory. The room is intended to be used as a "cold room," and the glazing area would remain under 75m³ (2,650 cu ft). My question is, do I need an additional building permit or planning permission for this in NRW?
Does anyone have information on this?
Member87
21 Feb 2022 10:55
Can no one tell me anything about this?
debaser21 Feb 2022 12:03
According to information online, conservatories up to 30m² (320 sq ft) in NRW do not require a building permit / planning permission. And even if it were 45m² (484 sq ft) – I would just go ahead and build it. No complainant, no judge.
i_b_n_a_n21 Feb 2022 14:30
Do you actually mean 75m³ (2,649 ft³) or m² (square meters / square feet)?
Do you have a simple sketch or photos?
I wouldn’t recommend doing this without approval: insurance issues if something happens, risk of having to dismantle, and much more.
Should the whole structure be fully sealed and remain unheated, or just "almost sealed"? In the latter case, it would be more like a sunroom.
Member87
21 Feb 2022 14:42
I mean 75m³ (2,650 ft³). The conservatory should be properly sealed, with windows, etc., and access to the house. However, it will not be heated.
The area is approximately 8 x 3.5 m (26 x 11.5 ft), with a covered terrace measuring 3.5 x 4 m (11.5 x 13 ft).
Grundriss: Haus links, Überdachte Terrasse rechts, Wintergarten mit Fenstern/Türen
apokolok
21 Feb 2022 15:42
If the area is 8 x 3.5 m (26.2 x 11.5 ft), it is exempt from the approval procedure; the volume is not relevant for this. The requirement, of course, is a 3 m (10 ft) setback from the property boundary. However, I would measure again carefully, as it is close to the 30 m² (323 ft²) limit.
