Hello
Are there good retrofit smart home systems available?
We bought a semi-detached house as a new build from a developer.
The electrician declined to work with KNX and said he is not familiar with it and won’t do it.
My question is: Are there good retrofit options for smart home systems that don’t require opening up the walls (that is not an option)?
Which systems would you recommend?
Functions:
Light control
Window sensors (preferably invisible)
Shutter control
Music control
Video doorbell
It should definitely be possible to create scenes and rules.
I’m also open to other suggestions for useful functions I may not have thought of yet.
Functions:
Light control
Shutter control
Music control
Video doorbell
I don’t necessarily need a server. I use a Raspberry Pi 4 with the Z-Stick 7 for my Z-Wave devices in Home Assistant. Data is stored on a NAS. The warmest device is still the Fritzbox. And yes, thanks to the central ventilation system, the heat output from the equipment can also be used for heat recovery :P
Pacc666 schrieb:
Is it possible to create automations with the Wibutler?Yes.Twenty-seven characters and five words
micric3 schrieb:
I don’t strictly need a server. I use a Raspberry Pi 4 with the Z-Stick 7 for my Z-Wave devices via HomeAssistant. The data is stored on a NAS. The warmest device is still the Fritzbox. And yes, thanks to the central ventilation system, the heat generated by the equipment can also be used for heat recovery :p So you don’t strictly need a server because you already have two :p
Pacc666 schrieb:
do you have any experience with the Wibutler?I've seen it from time to time at trade shows, but personally, I'm not interested, so my knowledge is limited to what I've found on Google or in brochures.
