ᐅ Floor Plan Design for a Single-Family Home of 230-235 m² on Two Full Stories
Created on: 11 Jul 2021 16:11
Hausbauer4747
By now, we have put quite a lot of thought into a practical, well-usable, and hopefully attractive floor plan, and we would like to reach a final decision fairly soon. We look forward to your feedback and thank you in advance for any tips or suggestions. 🙂
Plot size: 2,600 m² (approximately 0.64 acres), completely flat
Site coverage ratio / floor area ratio: 0.4 / 0.8
Number of floors: two full stories
Roof type: hip roof or pyramid roof with 22-25° pitch
Architectural style: modern
Orientation: the floor plans are always aligned with north at the top; the street side is on the east
Maximum heights / limits: the eave height is somewhat tight at 6 meters (approximately 20 feet), otherwise there is plenty of space. Building envelope and setbacks are sufficiently large, so we do not need to apply for any exceptions from the development plan.
Homeowners’ Requirements
Style, roof type, building type: “urban villa,” hip or pyramid roof with 22-25°
No basement, two full stories
Two adults, three children currently under 3 years old
Room needs on ground floor and upper floor: three children’s bedrooms with a children’s shower bathroom, guest room and office as two separate rooms
Ground floor with rather open architecture
A gas fireplace is an option, but we are likely to forgo it due to the effort of connecting gas and chimney costs
Both garage and carport planned (approx. 6x9 m (20x30 feet) garage and carport about 4x7 m (13x23 feet) located between the house and garage)
Planning origin: self-designed based on a discussed external dimension of about 12x12 meters (approximately 39x39 feet)
What do you particularly like and why? The house is relatively large and accommodates all room concepts (3 children’s bedrooms with children’s shower bathroom, separate guest room and office, etc.). We like the orientation by cardinal directions (living room southwest, children’s rooms south or southwest, master and guest bedrooms west facing the garden, bathrooms to the east, and front door facing north).
What do you dislike and why? The design focuses primarily on usability rather than aesthetics. For example, representative hallways with little practical use were avoided. However, it is difficult for us to achieve symmetrical and visually pleasing window alignment between the ground and upper floors. This is visible, for example, in the window of the children’s shower bathroom and the utility room below it.
Preferred heating technology: ground source heat pump, but for cost reasons, it will probably be an air-to-water heat pump.
If you have to give up, which features or additions could you do without
- What can you give up: KfW40+ with large photovoltaic system (instead opting for KfW55 with medium photovoltaic system), brick cladding, underfloor cooling, en-suite guest bathroom, showers could possibly be smaller if costs get too high
- What you cannot do without: children’s shower bathroom, (preferably) controlled ventilation system (mechanical supply and exhaust)
Are we overlooking anything in this floor plan that would annoy us daily later because it is poorly or very impractically planned? Can we find a visual trick to achieve exterior symmetry?
Many thanks!
Ground floor plan: Living 57.0 m² (613 sq ft), Kitchen 14.0 m² (150 sq ft), Guest 13.8 m² (148 sq ft), Hall 8.9 m² (96 sq ft), WC 1.5 m² (16 sq ft).
Upper floor plan: Master bedroom, three children’s rooms, office, hall, dressing room, bathroom and showers.
nordanney
13 Jul 2021 13:00
Hausbauer4747 schrieb:
Regarding completely custom architectural design, we would be interested to know if you all implemented this with your houses.
We did (with the last house). It was also necessary since we needed three children's bedrooms, a kids’ bathroom, and two home offices. It was a modest 300 sqm (3,230 sq ft) house.
based on your own experience
Definitely!
if you built "conventionally"
Conventional also means working with an architect.
we would appreciate photos and floor plans for inspiration
Ground floor plan: kitchen, entrance hall, living/dining, utility room, WC, stairs, carport
First floor plan: master bedroom with walk-in closet, bathroom, hallway, 3 kids’ bedrooms Izabel, Louise, Sophie.
I’ll skip the first floor.
11ant13 Jul 2021 13:20
Regarding fully custom architectural planning, we are interested to know if you all have implemented this approach for your houses and are convinced by your own experience.
I am a happy tenant and only advise others on planning; I took over my business with an existing building. But yes, I firmly believe that an architect should ideally have two degrees of freedom: a “freelance architect” in the sense of not being employed by or contracted to a general contractor; and not being burdened by clients with “remodeling” mixed salads of DIY drafts and random internet pictures instead of receiving a proper commission.
Or if you built in a more “traditional” way and based on that experience would go with a freelance architect next time?
Planning with a freelance architect IS “traditional” — it doesn’t get more tried and tested than that!
If everyone has built with architects, we would appreciate photos and floor plans for inspiration, even if some details differ (different number of children’s rooms or similar).
Oh, then it seems you still don’t quite understand: tailor-made patterns for OTHER PEOPLE’S custom suits will not fit you any better than an off-the-rack catalog model. The advantages of architect-designed plans are not visible in photos except that “you see that you see nothing”; they don’t have a red sole or anything like that ;-) [wrong! — like the second! — THAT is quality!]
11ant13 Jul 2021 13:28
HausTmMike schrieb:
Send me a private message, I can’t send messages yet
Then you cannot receive any either, and your request is pointless unless you provide your address: either add it under "Information" in your profile or post it here while the person you want to contact is also online (the latter is important because you can only delete it again within a limited time – as far as I know, within ten minutes).
K1300S13 Jul 2021 13:37
If you can’t send messages, you won’t be able to receive any either.
K1300S13 Jul 2021 13:41
nordanney schrieb:
I’ll skip the attic.
The example is only somewhat helpful here because not all requirements are covered in these two floors. Would the original poster also want or accept an attic space?
Hausbauer4747
13 Jul 2021 13:53
From the floor plan shared by @nordanney, I take away a positive point for myself: the stair landing and the approximately 1.70 m (5 ft 7 in) wide hallway provide a good opportunity to bring natural light into the upper floor hallway (although, as mentioned, this is not a must for us). We want to avoid an attic; currently, with the basement, we have four floors, which is not ideal. We originally wanted a bungalow, but especially the issues with excavation and disposal are a nightmare, and our hallways would have been very long. We prefer a concrete ceiling above the upper floor and would rather not have additional living space above it (even though I know there are companies that build solid roofs not from wood).
