ᐅ Floor Plan Design – Townhouse with Hipped Roof, 10x12 m
Created on: 17 May 2021 10:09
Bauthaler
Plot size 655 m² (7,050 sq ft)
Slope gradient 1.50 m (5 feet) over 30 m (98 feet) length
Floor area ratio
Floor space index 0.4
Building envelope, building line, and boundary the usual plus a 5 m (16 feet) green strip on the east side, which must remain undeveloped
Edge development
Number of parking spaces Double garage or garage plus carport
Number of floors 2 full floors plus finished attic or granny flat
Roof type hipped roof
Architectural style Mediterranean townhouse
Orientation
Maximum heights/limits ridge height (FH) 10.50 m (34.5 feet), eaves height (TH) 6.50 m (21 feet)
Additional requirements
Style, roof type, building type Mediterranean townhouse with hipped or pyramid roof, preferably bay windows or gables, not just box-shaped
Basement, floors with basement
Number of occupants, age Family of 4 persons
Space requirements on ground and upper floors 2 work/guest rooms, one as a granny flat or in the attic, 2 bathrooms, pantry adjacent to the kitchen
Office: family use
Overnight guests per year often family, childcare
Open or closed architecture rather open
Conservative or modern construction style good middle ground
Open kitchen, cooking island open dining-cooking area, separate from living room
Number of dining seats 1
Fireplace if possible
Music/stereo wall
Balcony, roof terrace
Garage, carport Double garage or garage plus carport
Utility garden, greenhouse
Additional wishes/special features/daily routine, also reasons why certain things are desired or not
Who created the plan:
- Do-it-yourself
What do you like most? Why? everything we wished for included, bedroom faces east, sauna in the basement, our existing furniture fits, cloakroom area for stroller
What do you dislike? Why? unclear if it is feasible as planned
Estimated cost according to architect/planner: 600,000 Euro
Personal price limit for the house, including equipment:
Preferred heating technology: air-to-water heat pump with underfloor heating
If you had to give up anything, which details/extensions
- Can give up: direct access from garage to house, fireplace
- Cannot give up: pantry, east-facing bedroom, spacious children’s rooms
We had discussions with several construction companies but never received a plan that met our wishes. That is why we took matters into our own hands. Neither of us has experience in this area, so we don’t know if our plan is good and feasible. Therefore, we hope for a lot of input here in the forum, where we have already found much inspiration and ideas.
Additionally, the “challenging” plot with a predetermined ridge direction from east to west while the lot is elongated north to south. We are negotiating with the municipality about changing the ridge direction but are unsure how realistic that is.
Thanks in advance for your thoughts on the floor plan!
Grundriss eines Obergeschosses mit Badezimmer, Ankleide, Schlafzimmer, Gast- und zwei Kinderzimmern.
Grundriss eines Hauses: Wohnzimmer/Essbereich, Küche, Büro/Gast, Diele, Speisekammer.
Kellergeschoss: Hobbyraum, Wellness (Sauna, Dusche), HWR/Technik, Werkraum, Waschküche, Vorrat.
Topografische Karte: pinke Flächen, Höhenwerte EFH 237,5, Kreis A, Kennzeichnung 8247.
Grundriss der Parzelle 8246 mit grüner Grenzlinie und Abmessungen in Metern.
11ant17 May 2021 16:55
Bauthaler schrieb:
The current setup works even without further exemption!
To be honest, I don’t even see how it works at all: how do you access the garage parking space at the lower end of the plan? Try drawing the house on the plot.
Bauthaler
17 May 2021 18:25
To be honest, I don’t even see if it will work at all: how do you access the garage space at the lower level? Try drawing the house on the plot.
It would of course be nicer WITH a change of the ridge direction.
Attached is a schematic of the house with the garage; behind the garage there should be a staircase following the natural slope of about 1.20m (4 feet) down to the basement.
It should be possible from the driveway to park 2 cars side by side in the garage, right? Or did you mean something else?
Site plan of plot 8246 with two blue buildings and dimensions in meters
K1300S17 May 2021 19:35
Bauthaler schrieb:
Price estimate according to architect/planner: 600,000 Euros
What exactly is included in these costs? And who made this estimate if there wasn’t even a finalized design yet?
GeradeSchräg
17 May 2021 19:35
Bauthaler schrieb:
Additionally, there is the "challenging" plot with a fixed ridge direction running east-west, while the plot itself is elongated north-south. We are negotiating with the local authorities about changing the ridge direction, but we are not sure how promising that is.
What about the rest of the neighborhood? Has everyone else followed the ridge direction? If not, the change should not be a problem.
To be honest, I don’t even see how it’s possible at all: how do you plan to access the garage space at the lower end of the plan? Try drawing the house onto the plot.
You can drive in, but getting out will be difficult =D
5.5m (18 feet) for a double garage is possible but far from ideal. Assuming a mid-size station wagon about 2.1m (7 feet) wide, two cars parked side by side would leave just over 30cm (12 inches) on each side per car to open the doors. Plus, you also have the garage door threshold to consider.
Honestly, how did you imagine getting out? Reversing along the street? You need a turning area. That’s why the house should be moved further down the plan.
K1300S17 May 2021 19:37
Bauthaler schrieb:
It should be possible to park two cars side by side in the garage from the driveway, right?
It’s doable, but quite tight. After some consideration, we decided against a nearly double garage with a width of 550 cm (5.5 meters / 181 inches).
K1300S17 May 2021 19:39
GeradeSchräg schrieb:
Two of these, then on each side per vehicle there is just over 30cm (12 inches) left to get out.
If your walls were made of paper. 😉
