ᐅ Click-lock engineered wood flooring: What installation methods are possible?
Created on: 17 Mar 2021 10:27
goronds
goronds
17 Mar 2021 10:27
we recently purchased click laminate flooring and would like to install it in a parallel pattern. Is this possible?
Are there any restrictions?
nordanney
17 Mar 2021 10:33
goronds schrieb:
We recently purchased click-lock parquet flooring and would like to install it in a parallel pattern. Is this possible?
Is it even possible to do it differently with the click system?
Usually not.
What type of parquet is it? Where will it be installed?
Tolentino17 Mar 2021 10:36
I suspect (!) the original poster means something different, specifically what is called a cross joint when tiling.
As far as I know, this should not be done with a click floor installed as a floating floor, due to stability reasons.
Myrna_Loy
17 Mar 2021 11:29
No, that is not possible without compromising the stability of the joints.
nordanney
17 Mar 2021 11:34
goronds schrieb:
Exactly, I’m not sure if a staggered pattern is stable enough for click-lock flooring.
Okay, understood the issue. That obviously doesn’t work with floorboards.
goronds
17 Mar 2021 11:39
Oh, okay, that's a pity! But thanks for the feedback.
