ᐅ Click-lock engineered wood flooring: What installation methods are possible?
Created on: 17 Mar 2021 10:27
goronds
we recently purchased click laminate flooring and would like to install it in a parallel pattern. Is this possible?
Are there any restrictions?
nordanney17 Mar 2021 12:04goronds schrieb:
Oh ok, too bad! But thanks for the feedback.It’s not too bad. Because with the floorboards, it actually looks pretty awful 😉 Staggered joint / one-third offset or a random pattern (which, besides the great look, also saves material).
nordanney schrieb:
It's not a shame. It actually looks rather poor with the floorboards 😉
Staggered joint/1/3 offset or a random pattern (besides looking great, it also saves material).Thanks, well, we find the straight parallel pattern nicer, but now we will probably go with staggered joint/1/2 offset.N
nordanney18 Mar 2021 09:05goronds schrieb:
Thanks, well, we just find the straight pattern more attractive.So why don’t you glue the parquet flooring fully if you really want the straight pattern? Problem solved.M
Myrna_Loy18 Mar 2021 09:09nordanney schrieb:
So why don’t you fully glue down the parquet if you really want a straight lay pattern? Problem solved.Or you could use room-length solid wood planks 😉
