ᐅ Floor plan for a single-family home with two full stories and a recessed/stepped top floor
Created on: 15 Mar 2021 22:05
StephanM
Dear Homebuilding Forum,
As a newcomer to your group, here is the completed profile of our building project:
Plot size: 637sqm (6860 sq ft)
Slope: no, completely flat
Site coverage ratio: 0.4
Floor area ratio: 0.8
Building window, building line and boundary: street frontage 17.6m (58 ft), 3m (10 ft) setback on left and right sides, building window 11.6m (38 ft) wide x 12.5m (41 ft) deep
Adjacent buildings: single-family houses
Number of parking spaces: two possible
Number of floors: 2 full stories plus 1 setback floor with flat roof (minimum 1m (3 ft) recess on all four sides)
Roof type: gable roof & flat roof
Architectural style: many options allowed as long as aligned with design guidelines
Orientation: south-facing
Maximum height/limits: 9m (30 ft)
Other requirements
Homeowners’ Requirements
Style, roof form, building type: simple, timeless, flat roof, cube-shaped
Basement, floors: basement, ground floor, 1st floor, 2nd floor as setback level
Number of people, ages: 2 adults, 4 children between 1 and 6 years
Space requirements ground floor, upper floors: ground floor approx. 105-110sqm (1130-1180 sq ft), 1st floor approx. 100-105sqm (1080-1130 sq ft), 2nd floor approx. 40-45sqm (430-480 sq ft)
Office: family use or home office? 1 home office
Guest bedrooms per year: very rare
Open or closed architecture: open concept
Conservative or modern construction: conservative design
Open kitchen, kitchen island: open kitchen with island
Number of dining seats: at least 6, extendable to 8-9
Fireplace: maybe, but chimney routing is a bit complicated
Music/stereo wall: no
Balcony, roof terrace: balcony on 1st floor to soften the building volume, possibly a roof terrace on the 2nd floor if not too complicated
Garage, carport: originally planned garage on one side including storage and carport on the other side, now tend to only carport as garage affects overall appearance
Utility garden, greenhouse: kindergarten ;-)
Other wishes/special features/daily routine, also reasons for why this or that should or should not be included
Who designed it:
Do-it-Yourself
What do you like most and why?
That it was possible to arrange spacious children’s rooms and create space for two bathrooms. Public living areas on the ground floor, children’s floor on the 1st floor, and parents’ area on the 2nd floor.
What do you like least and why?
I’m uncertain about the positioning of the bathrooms relative to each other (complexity due to drainage pipes), and which staircase best serves the 1st floor layout. The building volume is still not ideal, but I have no further ideas on how to meet the zoning requirements.
Price estimate according to architect/planner: 640,000 EUR
Personal price limit for the house including fittings: approx. 700,000 EUR
Preferred heating system: geothermal
If you have to give up something, which details or extensions
- can you do without: additional room in the setback floor, terrace in the setback floor, already gave up on double garage as it overly restricted the floor plan :-( possibly external basement stairs
- cannot do without: 4 large children’s/teenage rooms, setback floor because we can’t fit all rooms on just 2 floors, basement as a lot of stuff accumulates with 4 children...
Why is the design like it is now? For example:
Because after many nights of planning I couldn’t come up with a better solution...
What makes it in your opinion particularly good or bad?
It meets our requirements on paper, but I lack the experience to judge whether it will work well in practice, which is why I’m asking for your opinions.
How can I best organize the living space (especially but not only the 1st floor) and use the proper staircase design to create a spacious hallway without wasting area?
That was quite a bit of work ;-) I hope this information is useful for the further discussion.
In the next post I’ll share the floor plans and some exterior views (if I manage the attachments...)
Thank you in advance for your time reviewing this and for your honest and constructive feedback on the current design!
Stephan
Other requirements
Who designed it:
Do-it-Yourself
Stephan
StephanM schrieb:
Attached is an overall site plan; we are planning with plot number 11. Access from the north is possible on both sides of the house. The blue lines are intended to represent surface water flow on the ground. I do not yet know the location of the utility lines, but they should be located just in front of the house (3m (10 feet) front yard).
Regards, Stephan
Such a spacious house, and yet you constantly have to maneuver the cars because they can only be parked one behind the other. 🙄
Two notes:
Two notes:
- If the zoning plan is up to date, the setback for the recessed top floor is not mandatory. It only needs to be less than 75% of the footprint of the floor below.
- The budget will not be sufficient. Either build smaller and/or skip the basement – or increase the budget (not the house).
Hello Stephan,
Regarding your three main questions anchored in the ground floor: no, no, no.
Parking spaces in tandem are generally not allowed.
A carport on the property boundary, rotating the utility room, placing part of it behind the carport also on the boundary, and using the exposed corner of the house/property as a parking space—that is possible.
Is it still going to be a utility cellar? Playroom? Where will the office be located?
Where does the architect come into play?
Edit: I confused the office with the utility room 🙄 Hello ypg,
I couldn’t quite follow the first part of your answer. What do you mean by three times "no"?
I understand the issue with parking spaces; unfortunately, a double garage is not feasible due to space constraints. I like your suggestion regarding relocating the office (the "utility room") towards the back. One question about that: the carport is already on the boundary, which is acceptable as an ancillary building, but what about an office? I assume I’m not allowed to place living space on the boundary, correct?
The cellar is planned to serve as a utility cellar.
We initially had an architect involved, but they eventually sidelined themselves... We are currently looking for a capable general contractor / masonry builder for a fresh attempt...
K1300S schrieb:
Just checked. The development plan is from last year, so point 1 of my previous statement applies. Good morning K1300S,
I share your assessment regarding maneuvering. Unfortunately, I don’t see another option right now except to have a carport on both sides of the house, which then looks a bit like Mickey Mouse ears… A double garage takes up too much living space on the ground floor.
As far as I understand development plan No. 900 of the city of Bochum, the textual version notes the following:
"2.2.4 Top floors
In general residential areas (WA 1), for buildings with flat roofs, an additional floor above the uppermost full storey is permitted if it is set back at least 1.00 m (3.3 ft) on all sides behind the vertical exterior wall of the lower full storey."
I understand this to mean that this development plan is stricter than the state building code, which only requires a setback of 75% of the floor area below. How do you evaluate this?
Regards
Stephan
