ᐅ Floor plan for a single-family home with two full stories and a recessed/stepped top floor
Created on: 15 Mar 2021 22:05
StephanM
StephanM
15 Mar 2021 22:05
Dear Homebuilding Forum,
As a newcomer to your group, here is the completed profile of our building project:
Plot size: 637sqm (6860 sq ft)
Slope: no, completely flat
Site coverage ratio: 0.4
Floor area ratio: 0.8
Building window, building line and boundary: street frontage 17.6m (58 ft), 3m (10 ft) setback on left and right sides, building window 11.6m (38 ft) wide x 12.5m (41 ft) deep
Adjacent buildings: single-family houses
Number of parking spaces: two possible
Number of floors: 2 full stories plus 1 setback floor with flat roof (minimum 1m (3 ft) recess on all four sides)
Roof type: gable roof & flat roof
Architectural style: many options allowed as long as aligned with design guidelines
Orientation: south-facing
Maximum height/limits: 9m (30 ft)
Other requirements
Homeowners’ Requirements
Style, roof form, building type: simple, timeless, flat roof, cube-shaped
Basement, floors: basement, ground floor, 1st floor, 2nd floor as setback level
Number of people, ages: 2 adults, 4 children between 1 and 6 years
Space requirements ground floor, upper floors: ground floor approx. 105-110sqm (1130-1180 sq ft), 1st floor approx. 100-105sqm (1080-1130 sq ft), 2nd floor approx. 40-45sqm (430-480 sq ft)
Office: family use or home office? 1 home office
Guest bedrooms per year: very rare
Open or closed architecture: open concept
Conservative or modern construction: conservative design
Open kitchen, kitchen island: open kitchen with island
Number of dining seats: at least 6, extendable to 8-9
Fireplace: maybe, but chimney routing is a bit complicated
Music/stereo wall: no
Balcony, roof terrace: balcony on 1st floor to soften the building volume, possibly a roof terrace on the 2nd floor if not too complicated
Garage, carport: originally planned garage on one side including storage and carport on the other side, now tend to only carport as garage affects overall appearance
Utility garden, greenhouse: kindergarten ;-)
Other wishes/special features/daily routine, also reasons for why this or that should or should not be included
Who designed it:
Do-it-Yourself
What do you like most and why?
That it was possible to arrange spacious children’s rooms and create space for two bathrooms. Public living areas on the ground floor, children’s floor on the 1st floor, and parents’ area on the 2nd floor.
What do you like least and why?
I’m uncertain about the positioning of the bathrooms relative to each other (complexity due to drainage pipes), and which staircase best serves the 1st floor layout. The building volume is still not ideal, but I have no further ideas on how to meet the zoning requirements.
Price estimate according to architect/planner: 640,000 EUR
Personal price limit for the house including fittings: approx. 700,000 EUR
Preferred heating system: geothermal
If you have to give up something, which details or extensions
- can you do without: additional room in the setback floor, terrace in the setback floor, already gave up on double garage as it overly restricted the floor plan :-( possibly external basement stairs
- cannot do without: 4 large children’s/teenage rooms, setback floor because we can’t fit all rooms on just 2 floors, basement as a lot of stuff accumulates with 4 children...
Why is the design like it is now? For example:
Because after many nights of planning I couldn’t come up with a better solution...
What makes it in your opinion particularly good or bad?
It meets our requirements on paper, but I lack the experience to judge whether it will work well in practice, which is why I’m asking for your opinions.
How can I best organize the living space (especially but not only the 1st floor) and use the proper staircase design to create a spacious hallway without wasting area?
That was quite a bit of work ;-) I hope this information is useful for the further discussion.
In the next post I’ll share the floor plans and some exterior views (if I manage the attachments...)
Thank you in advance for your time reviewing this and for your honest and constructive feedback on the current design!
Stephan
StephanM
15 Mar 2021 22:13
Now the floor plans and some elevations...
Floor plan of a house with multiple rooms, central staircase, and dimension markings.
Floor plan of a single-family house: living area, dining area, kitchen, bedroom, bathroom, staircase, garage.
Floor plan of an apartment level with bedrooms, kitchen, bathroom, and area specifications.
Floor plan of a residential house with kitchen, bathroom, study, bedroom, and hallway.
Modern gray brick house with white extension, carport, and yellow car on green lawn.
Modern white multi-story house front with carport; two yellow cars parked under the carport.
Modern gray brick villa with large window fronts on green lawn.
Modern multi-story house facade with stone cladding, glass fronts, and yellow car in the carport.
haydee
15 Mar 2021 22:52
Finally, no dollhouse furniture table with chairs pushed in at the table.
I
icandoit
15 Mar 2021 23:04
Please provide a site plan showing the north arrow, access road, and utility lines.
15 Mar 2021 23:07
Hello Stephan,
Regarding your three main questions, which are anchored in the ground floor: no, no, no.
Well, I’m not entirely sure about the balcony, but who really needs a balcony except maybe for smoking.
Furthermore, the floor area ratio / plot ratio is already quite generous, so hardly any arguments seem reasonable (it would be different if a floor area ratio of 0.2 only allowed 100 m² (1,076 sq ft) and you already lived there, now expecting twins and needing to expand the house. That would be a social factor that might justify an extension as a remodeling measure permitting additional building). But that’s not the case here!
Parking spaces arranged in tandem are usually not allowed.
A carport built up to the boundary, rotating the utility room, using part of it behind the carport also as boundary development, utilizing the exposed corner in front of or next to the house as a parking space – these options are possible.
Keep in mind: 100 m² (1,076 sq ft) of living space costs about $220,000, basement $100,000. Every balcony, recessed area, or roof terrace adds extra costs.
Four children don’t need two bathrooms, a house for six doesn’t need four toilets.
Children don’t need a balcony, and 15 m² (161 sq ft) is enough. Costs easily add up to $700,000 if you include every little luxury. Then it can still become a cool house. The concept is there!
Is the basement still just a utility cellar? A playroom? Where will the office be?
Where does the architect come into play?
Edit: I confused the office with the utility room 🙄
StephanM
16 Mar 2021 00:06
icandoit schrieb:
Please provide a site plan showing the north arrow, access road, and utility connections.
Attached is an overall site plan; we are planning with plot No. 11.
Detailed site plan of a residential area with plots II+/IV+, promenade with canal and raingarden.
