ᐅ Floor Plan Optimization for a Single-Family Home of Approximately 150 sqm on a Small Plot
Created on: 18 Aug 2020 20:31
Yaso2.0
After what felt like forever, we finally received the floor plan (without exact dimensions) today from our preferred general contractor. Although the planner noted our requests during the meeting, some of them don’t seem to have been fully incorporated.
The price offer will be prepared once the floor plan is finalized, especially if the size increases.
I would like to share the floor plan with you and hear your suggestions for improvements!
Plot size: 389sqm (4187 sq ft)
Sloping site
Site coverage ratio 0.35
Floor area ratio 0.70
Edge development
Number of floors: 2
Roof type
Architectural style
Orientation
Maximum heights / limits
Additional requirements
Client requirements
Architectural style, roof type, building type: City villa
Basement, number of stories: 2 stories, no basement
Number of occupants, ages: 3 persons (44, 38, 9)
Kitchen, living room, guest WC, utility room, and if possible, a small office
Guests for overnight stays vary widely
Open or closed architecture partly/partly
Conservative or modern style: a healthy mix of both
Open kitchen, kitchen island: semi-open kitchen, kitchen island not mandatory
Number of dining seats: 6–8
Fireplace: possibly
Music / stereo wall
Balcony, roof terrace
Garage, carport
Utility garden, greenhouse, garden for pleasant evenings
Additional wishes / special features / daily routines, including reasons why certain elements are wanted or not
We want a larger but semi-open kitchen because I cook and/or bake daily. A pantry would be great but I would also give it up if it means more counter space in the kitchen.
Ideally, I would like a laundry room on the upper floor since all the laundry tasks happen upstairs.
Planner:
What do you particularly like? Why? Pantry room,
In the upper floor, the bedroom does not directly adjoin the children’s rooms
What do you dislike? Why?
Kitchen accessible only through the living room, hallway seems like wasted space??, kitchen counter size too small,
Cost estimate by architect/planner: still open, to follow after floor plan and house size are finalized
Personal budget limit for the house including fixtures and fittings:
Preferred heating system:
If you had to compromise, on which details / additions
- Could you do without: walk-in closet
- Could you not do without: “larger” kitchen
The general contractor’s planner asked about our preferences and created the floor plan accordingly. Apparently, an office didn’t fit. The requirement was that we ideally don’t want more than 150sqm (1615 sq ft), a kitchen size of at least 13sqm (140 sq ft) would be nice, and if possible, no straight staircase.
What makes it particularly good or bad in your eyes?
The hallway seems to take up too much space without much utility, the kitchen feels too small.
The walk-in closet is “enclosed” and should be accessible via the corridor.
We like that the children’s rooms are exactly the same size. The future child planning is currently flexible.
How can we make the kitchen accessible through the hallway and semi-open, without making it too small?
Would a different staircase allow for a better layout?
Or are our wishes not feasible within 150sqm?
Thanks in advance!
Sloping site
Edge development
Number of floors: 2
Roof type
Architectural style
Orientation
Client requirements
Fireplace: possibly
Music / stereo wall
Garage, carport
Planner:
Thanks in advance!
Alessandro19 Aug 2020 11:25I wouldn’t do without the pantry! Even if it’s narrow. Beverage crates, handheld vacuum cleaner, blender, and everything else that shouldn’t be left out in the kitchen will definitely fit in there!
Or where else would you store the drinks?
They won’t all fit in the utility room (I assume you also want to dry or iron laundry there).
Alessandro schrieb:
I wouldn’t skip the pantry, even if it’s narrow. Crates of drinks, handheld vacuum cleaners, blenders, and everything else that shouldn’t be left out in the kitchen will definitely fit in there!
Otherwise, where else would you store the drinks?
The utility room (I assume you also want to dry or iron laundry there) probably won’t have enough space for all that. Two large, floor-to-ceiling tall cabinets, 60 or 80cm (24 or 31 inches) wide, can accommodate all of that. And if you remove the pantry, on the left side of the kitchen you’d end up with about three meters (10 feet) of tall cabinet front... with the countertop running continuously on the right side.
Yaso2.0 schrieb:
Access to the kitchen through the hallwayHowever, this unfortunately complicates the kitchen layout planning.A
Alessandro19 Aug 2020 12:51Alessandro schrieb:
I wouldn’t give up the pantry! Even if it’s narrow. Drink crates, handheld vacuum, blender, and everything else that shouldn’t be left around the kitchen will easily fit in there!
Or where else do you want to store the drinks?
They won’t fit in the utility room (I assume you want to do laundry drying or ironing there, too). Tall pantry cabinets are planned to be integrated into the kitchen, which should accommodate that.
We don’t have crates for water, for example. The beer comes in six-pack carriers, and the handheld vacuum is mounted on the wall.
Scout schrieb:
Two large, floor-to-ceiling tall cabinets 60 or 80cm (24 or 31 inches) wide will swallow all of that. And on the left side of the kitchen, with the pantry eliminated, that’s about three meters (10 feet) of tall cabinet frontage... The countertop then runs continuously on the right side. Exactly, pantry cabinets are supposed to be included in the plan.
Pinky0301 schrieb:
But that complicates kitchen planning. In what way? My idea is to plan the door from the hallway as a sliding door, then start an L-shaped kitchen plus a boxed-in kitchen area where the pantry can also fit.
I’ll add some example pictures of how I would like it to look, but the dimensions are still missing.
Alessandro schrieb:
You could shift the hallway slightly toward the stairs, make the utility room smaller, and place the washer and dryer in the resulting office space.
This way, you get a larger ironing/laundry room that can also double as an office. The cloakroom will also be bigger as a result.
