ᐅ Meister Lindura Hardwood Flooring HD 400
Created on: 30 Jun 2020 22:11
Dominik Weber
Dominik Weber
30 Jun 2020 22:11
Does anyone have experience with the Meister Lindura wooden flooring, the newer HD 400 generation? Would you recommend this floor, or would you advise against it?
We are considering installing this flooring in our new build.
Thank you in advance for your answers.
Dominik
pagoni2020
30 Jun 2020 22:28
We had the same idea a year ago, back then with the previous model. There are great widths available, but I couldn’t find much information anywhere.
A friend of mine works at a sawmill, and he is enthusiastic and hasn’t heard any negative feedback.
Now, with our new house, we will face the same question again, this time with the HD400 model. Meister is a solid company, and I can’t imagine it being low quality. What little information I found mentioned that the floor is very durable, but on the other hand, they explicitly recommend using furniture pads under chairs... which is something you should do anyway, to protect any floor.
We decided on Meister, but for parquet, I believe the 2nd grade version called ..200. We have 160 sqm (1722 sq ft) of it here, and I could use the same again. For me, it’s effectively 1st grade, technically solid and visually almost no waste. The price was €25 (about $27) gross!
We installed it as a floating floor over underfloor heating and I will do that again. It creaks only in a few spots occasionally, but in the worst case, I can replace individual planks.
So for me, it’s an option, especially the 2nd grade for such large areas. I wouldn’t have any concerns about quality; it looks great anyway.
JuWe2020
21 Jul 2020 21:16
I strongly advise against the Lindura flooring! We had 250 square meters (2,700 square feet) installed in our house, and after just one year, the floor looks terrible. The top layer is peeling, there are countless scratches, and some knots have even broken out. From the beginning, we followed the recommended care instructions and oils, took off our shoes immediately in the hallway, and yet the floor appears extremely worn and aged.
The inspector from the Meister company was rude and, among other things, claimed in a letter that we had not used a doormat, even though there were two mats in the hallway when he came for the appointment. He also suggested that our 14-year-old son caused the broken out knots with force, and so on! We are very dissatisfied and upset and are considering legal action. The advertising claims do not match reality at all! We regret not choosing hardwood flooring. In my husband’s practice, there is a 90-year-old hardwood floor (protected as a listed building), which still looks great even though about 100 people walk over it daily! Our Lindura floor looks absolutely awful in comparison!
I cannot recommend this floor at all. We were especially sold on its durability, which is completely lacking. I can only warn everyone against this flooring!!!!
Dominik Weber
21 Jul 2020 23:26
JuWe2020 schrieb:
I strongly advise against the Lindura flooring! We had 250 square meters (approximately 2,700 square feet) installed in our house, and after just one year the floor looks terrible! The top layer is peeling off, there are countless scratches, and some pieces of wood have even broken out. From the very beginning, we used the recommended oils and care products, always took shoes off right in the hallway, yet the floor still looks extremely worn and aged. The expert from the company Meister was rude and claimed in a letter, among other things, that we hadn’t used a doormat, even though there were two mats in the hallway when he came for the inspection... He also said that our 14-year-old son caused the broken-out pieces through force, and so on! We are very dissatisfied and upset and are considering legal action. The advertising promises did not match reality at all! We regret not choosing parquet. The floor in my husband’s practice is a 90-year-old parquet floor (a listed building), which looks perfect even though about 100 people walk on it daily! In contrast, our Lindura floor simply looks awful!!!! Absolutely no recommendation to buy. We were especially told about the floor’s durability, which is absolutely not true. I can only warn everyone against this flooring!!!!
That really sounds awful, especially after only one year. Do you happen to have any pictures you’d be willing to share? So far, every specialist dealer has only given me positive feedback about this flooring. But a report like yours certainly makes you think... Thanks very much for sharing your experience.
JuWe2020
22 Jul 2020 07:52
Dominik Weber schrieb:
That sounds really bad, especially after just one year. Do you happen to have any pictures you can share?
So far, I’ve only heard positive things about the flooring from every specialist store. But a report like this certainly gives you pause...
Thanks anyway for your contribution.
Close-up of a wood surface with many fine scratches and circular marks.
Wood surface with visible grain, knots, and light scratches.
Close-up of a round wood knot in the board with radial lines and a gray core.
Close-up of two wooden floorboards showing grain and visible knots.
Brown wooden floor made of planks with visible grain and a round knot.
JuWe2020
22 Jul 2020 07:54
I hope the damage is visible. Above all, I find it incredible that the company Meister doesn’t respond to it at all. Best regards
