Created on: 27 May 2019 10:48
goalkeeper
Wickie
18 Dec 2019 08:58
For planning electrical outlets, I’ve always found it helpful to mentally walk through the house with a vacuum cleaner. Additionally, consider lighting (floor lamps, table lamps), where devices will be charged… Kitchens are usually quite straightforward. The note about the bathroom (hairdryer, electric shaver) has already been mentioned. Just run through your daily routine!
It’s always worth putting serious thought into lighting! I always find it unsettling when the living room’s light above the coffee table is planned as a pendant light or when the entire place is packed with recessed spotlights. Maybe that was done 30 years ago due to a lack of other options.
kaho67418 Dec 2019 09:04
Also, maybe consider:
- Two-way switches in stairways, hallways, bedrooms (simulate walking routes)
- Switchable outdoor socket (security risk), possibly a timer switch for the outdoor socket under the entrance canopy (Christmas star)
- Sockets controlled by light switches in the bedroom for wardrobe lighting (possibly also living room)
- Wi-Fi often has poor reception through concrete ceilings! With multiple floors, it’s better to have wired connections with a transmitter on each floor.
- Roller shutters controlled centrally? We have an "all up or down" switch next to the front door.
Scout
18 Dec 2019 09:14
LAN? At minimum, in the home office, in the media corner of the living room, and one access point per floor. Beyond that, it’s mostly a matter of personal preference.
Towards the parking space, at least a thick empty conduit or directly 5x4 mm2 (5 x 12 AWG) cables from the main distribution board. It doesn’t necessarily have to be connected immediately.
RomeoZwo18 Dec 2019 09:15
Do you have KNX or another smart home system?
If wall lights are desired as ambient lighting, don’t forget to make the wall outlets dimmable. We forgot this, but thanks to KNX it can be solved with an additional dimmer actuator.
For the work surface lighting in the kitchen, also provide a switched outlet. It’s convenient to be able to turn it on directly at the light switch.
For LAN, also plan a power outlet next to the access point (or use PoE, but access points are significantly more expensive then, and the router must support it as well).
hanse987
18 Dec 2019 10:02
RomeoZwo schrieb:
When planning LAN, also include a power outlet nearby for the access point (or go with PoE, but the access points are significantly more expensive and the router must support it).
PoE access points are not much more expensive, and since they do not require power outlets, they are much easier to mount on the ceiling or high on the wall. The router does not need to support PoE—in fact, none of the routers I know have PoE built-in; instead, a PoE injector is used, or for multiple devices, a PoE-capable switch.
U
UpperEast
18 Dec 2019 10:02
RomeoZwo schrieb:
When planning LAN, also include an electrical outlet nearby for the access point (or use PoE, but then the access points are significantly more expensive and the router must support it).
Definitely go for PoE. With so many LAN outlets, the power won't come from the router anyway.
I completely agree regarding KNX; if you want nice lighting, then use KNX.
